GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470
Old 04-03-11, 07:45 PM
easgx470
easgx470's Avatar
Thank you!!!!
Old 04-10-11, 08:54 AM
MWalker
MWalker's Avatar
Thanks a bunch, just had to chance one out myself.
Old 04-17-11, 10:04 AM
mann777
mann777's Avatar
Jeffo, sorry to get this topic back, it has been almost 7 years that the turn bulb which was since OEM installation, begin to show some kind of color discoloration, And I wanted to replace it. So I started to remove the bulbs, and look what I found. These are OSRAM 1156A LF - Mercury coated bulbs, and not available in the dealer or the online sites. As did during its initial days this was really bright but later faded and began to more whitish. And then I wanted to replace with the Sylvania stuff like you did, more of an orangish color it seems. . Here is the post installation look.
The images are loaded in sequence for info only,
1. The First Image is the OEM Osram Bulb 1156A Mercury Coated.
2. The Second Image is close up of the bulb specs , with the Mercury coat peeled off in certain areas.
3. The New Sylvania fitted.
4. The Turn+DRL on with the Parking LEDs ( wedge type )
I do want to hear from others have they experienced this while replacement that have they found the Mercury coated bulbs within.
Attached Thumbnails Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470-turn-bulbs-and-drl.jpg   Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470-osram-1156a-lf.png   Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470-new-1156a.jpg   Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470-with-the-parking-lite-on-leds.jpg
Old 04-17-11, 02:41 PM
redrocks
redrocks's Avatar
Mann,
Are the "Turn+DRL on with the Parking LEDs" white as DRL and amber when turn indicator come on?
Old 04-18-11, 09:27 AM
mann777
mann777's Avatar
Nopes, the parking Lite is white and the DRL+turn continues to be Amber. But the Parking lite gets activated in park mode via the multiswitch & gets deactivated when in Headlamp mode. The DRL+turn is a single filament bulb but has a dual function, it is just when the turn gets activated manually by the driver, the DRL goes off. Hope this is what you requested. cheers
Old 04-18-11, 11:49 AM
redrocks
redrocks's Avatar
I thought you might have installed switchback lights by V-LEDs, which change to amber when turn indicators are used.
http://www.v-leds.com/Exterior-LED/T...viewsTabAnchor
Old 04-23-11, 09:06 AM
mann777
mann777's Avatar
yeah I have seen that on one Camry via the you tube. Done awesome http://www.youtube.com/watch?v=nhETq...layer_embedded
I am currently doing the mod will put up once it is over. But not the switch back
Old 04-25-11, 09:10 AM
DSchmitz
DSchmitz's Avatar
Hi guys. I have the capability to get many of those part stores to change their application data for the turn signal. This would help anyone else that goes to an auto store to get the correct part number instead of being given a 4157 or another wrong lamp. I would like to verify a few things first though.
Lexus informed me that the bulb has offset pins. To me this indicates it would be an 1157NA. The 1156NA has pins that are level with each other. Could someone double check whether the pins are level with each other or if one is higher than the other. Also if you could tell me whether there is 1 or 2 filaments inside of this bulb it would help me narrow down the possibilities.
Thank you!
Old 04-25-11, 10:53 AM
mann777
mann777's Avatar
This image attached should solve all your doubts, GX Models from 2003-2009 the headlamps design has not changed either Exterior or Interior. So If lexus is telling you this, Simple he is not aware of his subject. I just replaced mine last week and here is one which was removed. And I replaced with Sylvania 1156. Hope this helps.
Attached Thumbnails Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470-dual.jpg
Old 08-05-11, 04:11 PM
pcj
pcj's Avatar
Default Thank you!
I have a 2005 GX470. Your directions were down-to-the-letter perfect.
Old 11-15-11, 08:26 AM
drewdogg80
drewdogg80's Avatar
Thanks for the post. My sister just called me today regarding her GX470, sent her this thread.
Old 12-10-11, 03:30 PM
marktoffee
marktoffee's Avatar
Thanks Jeff,
Took your advise and changed the bulb on my 2003 GX in less than 5 min. You really helped me out.
Old 12-12-11, 11:51 AM
GXM35
GXM35's Avatar
Default Question
Does this advice hold true for both sides? I replaced mine from above on the non-battery side with little problem, but when I looked at the side with the battery, I saw there may be trouble changing it...
Old 12-19-11, 06:40 AM
rbx10
rbx10's Avatar
Jeff thanks
Have a Merry Christmas
Old 12-28-11, 05:24 PM
Trini470
Trini470's Avatar
Excellent post Jeff. Thank you.
Did it in a couple mins in the parking lot of pepboys!
Quick Reply: Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470
