GX - 1st Gen (2004-2009) Discussion topics related to the 2003 -2009 GX470 models
Disable Tire Pressure Sensors?
Old 06-09-17, 06:10 AM
  #76
NTH
NTH's Avatar
Originally Posted by burtoncr
Still works fine. I actually wired in a switch so I could go back to using the stock tires / rims with pressure sensors. I verified that I can switch back and forth and everything works as it should.
So finally had some time yesterday to attempt this mod for the 07+ GX. Worked just as described. Thank you, burtoncr!
Just a note to help clarify things for others:
1. My 07 has the blue TPM box
2. Disconnect harness from blue box then cut the BLUE wire.
3. Strip some insulation away from the GREEN/RED wire and tap it to the BLUE wire going to the dash. (Note: make sure you don't tap the green/black wire right next to it)
4. Reconnect wire harness to Blue TPM box
5. Done!
Old 08-07-17, 07:40 PM
  #77
rlabair
rlabair's Avatar
Just completed this mod. Followed directions provided in the thread, took about 15 minute and light is off. Thanks all!
Old 11-07-17, 01:34 PM
  #78
golfmanpat
golfmanpat's Avatar
Default 2007 tpms bypass
Originally Posted by NTH
This didn't work for my '07 either. I've tried both ends of the cut blue wire but light still flashing then steady.
I just did this on my 2007 and it worked! Make sure you connect to the green and red one and not the green and black one.
Old 11-07-17, 06:27 PM
  #79
NTH
NTH's Avatar
Lol! See my post #76.
Old 11-07-17, 08:28 PM
  #80
golfmanpat
golfmanpat's Avatar
Lol my bad! I guess I skipped over it before. Thanks!
Old 11-08-17, 12:52 PM
  #81
Dx3
Dx3's Avatar
Wish I would have seen this before I wasted $180 on sensors!
angelslex (07-01-20)
Old 01-16-18, 06:14 PM
  #82
NTH
NTH's Avatar
Has anyone gotten error codes or pending codes from disabling your tpms module? I’m curious cuz the ECU must see this as a malfunction with the module.
Old 01-17-18, 08:03 AM
  #83
angelslex
angelslex's Avatar
Wow! I didn't realized this thread still alive...
I must of had a Nokia or a Razor Motorola phone. Pictures sucks!! Lol
i did this back in 2005 and I never had a problem with errors or escu.
change tires, change rims and all. Zero problems
Old 01-17-18, 08:19 AM
  #84
IanB2
IanB2's Avatar
I don't think this module is tied into the ecu for anything. I've had the mod done for 3.5 years with no ill effects.
Old 01-17-18, 07:44 PM
  #85
NTH
NTH's Avatar
Thanks for the feedback guys. I did the mod several months ago and no issues so far. I was just curious
Old 01-21-18, 07:05 PM
  #86
Dilliardj
Dilliardj's Avatar
Worked like a charm, Thanks. 😎
angelslex (01-22-18)
Old 04-23-18, 12:53 PM
  #87
rjellis
rjellis's Avatar
5. Done!
Have an '07 Nav like you. Did exactly as noted above. TPMS light is out - yay!
BUT....The three VSC related lights are all on now. Anybody else experience this?
Yes, I did connect Blue to Green/Red. Let me ask this - what # position in the plug is your green/red in?
Old 10-04-18, 08:25 PM
  #88
LoganDon
LoganDon's Avatar
I would like to thank everyone that contributed to this thread. I used my '06 gx470 to tow my pop up camper from AZ to northern ID and back and started by inflating my rear tires to max. Soon, the tpms came on, blinking, and stayed on for 2500 miles. I reset all tire pressures to specs of 32# once home and went to Discount Tires who promptly said all sensors were dead. As I am 75 and have driven on tires prepped by an air gauge for over 60 years, figured I did not need the tpms. Followed instructions completely and completed the job in a couple of hours which I consider good considering my age, arthritis, Vietnam war injuries, etc. the grounding of the wire was complete. Thanks for articles like this!
Old 11-21-18, 02:11 PM
  #89
fozzir
fozzir's Avatar
I did it thanks for these instructions but I grounded it to a nut on the lower A piler about 5 inches above the floor. Had to peel away some lower paneling to find it.
Old 12-18-18, 06:39 AM
  #90
Arailt
Arailt's Avatar
Hey everyone. I decided to solder the posts in the TPMS box itself to avoid cutting/splicing wires. I had some help from Mud members and used burtoncr's advice to find the Blue and Red/Green wires, then soldered their corresponding posts. Worked like a charm. I'll note that my 2008 had a different TPMS module than what I have seen folks post for the 2007 and 2003-2006, but the Blue and Red/Green wires are still the correct wires.
Here's the end result. the board slides right out after you pop the plastic top on the TPMS box. Super easy. It took me 15-20 minutes total and I have never done anything like this in the past, so it's easy for a complete noob.
BeEvil (02-08-19)
Quick Reply: Disable Tire Pressure Sensors?
