All interior LEDs work, except Drivers side map light?
Old Nov 27, 2022 | 06:12 PM
dC0m's Avatar
dC0m
1st Gear
Default All interior LEDs work, except Drivers side map light?
Long time listener, first time caller here - '08 GX470.
The other day, I replaced my interior lights with LEDs and everything was fine and dandy, except the driver's side map light. When switched to the door position, it doesn't turn on and when manually turned on, I need to click it several times for it to "light". It does get power when you manually click it, but not right away (takes several clicks).
Checked the fuse (not broken, and all other lights in the interior work) in the engine bay, swapped the bulbs around to the passenger side (worked fine on pass. side), and even cleaned the connection where the bulb makes the connection.
Any other ideas before I start tearing it apart to find a break in wiring?
Old Nov 29, 2022 | 11:01 PM
Arsenii's Avatar
Arsenii
Hello,
Those older models had an issue with new LED lights as they draw a lot less than regular incandescent bulbs, which resulted strange behavior at best, and fried Body ECU at worst. There are LED bulbs out there designed with higher resistance, but I wouldn't dare my luck frankly..
Hope this helps and best of luck!
Old Nov 30, 2022 | 03:16 AM
ALAN553's Avatar
ALAN553
Did mine…no issues. Maybe a bent contact point, not tight enough?
DonLogab
May 5, 2022 04:37 PM
GmanSC
Jan 14, 2022 09:23 PM
Tieguy77
GX - 1st Gen (2003-2009)
Nov 29, 2019 04:15 PM
PirelliRC
Mar 15, 2015 09:45 AM
Michael
Jan 8, 2014 09:06 PM
