Display Panel Message
Old May 13, 2012 | 02:29 PM
Walley's Avatar
Walley
Default Display Panel Message
I just recently got my GX about a week ago and yesterday i took it for it longest drive to the airport to pickup a friend and back. This morning i get in to run a few errands and to my surprise i get these visual indicators on my dash. i definitely did not see this yesterday so im in a little state of panic especially since my car was sold without warranty. what do you guys think?
Old May 13, 2012 | 04:56 PM
RCsGX's Avatar
RCsGX
Could be a number of things. You need to get the codes using a OBDII scanner to know for sure. It could be as simple as a gas cap not tightened all the way.
Old May 13, 2012 | 08:14 PM
cdew002's Avatar
cdew002
Like RC says - tighten the gas cap.
Old May 14, 2012 | 11:36 AM
clubsport's Avatar
clubsport
i decided not to work this morning and work at home... so i went out to the garage and saw a bottle of gas tx leftover and decided to pour the remainder in my truck... now i get teh vsc trac/off and cel on... the gas cap is tight but the light still on... anyone? or should i just disconnect the battery but i hate to have to reprogram the doors/locks and windows again...
Old May 14, 2012 | 04:49 PM
Walley's Avatar
Walley
thanks guys! i went to the dealer and it turned out the problem was the gas cap. they replaced it and reset the code. im all good now
Old May 14, 2012 | 05:48 PM
clubsport's Avatar
clubsport
hey walley, what did they say was the matter with the gas cap?
Old May 14, 2012 | 07:08 PM
clubsport's Avatar
clubsport
also, is there any other way to clear the codes lights from our lexus? thanx
Old May 15, 2012 | 03:13 AM
Ancient's Avatar
Ancient
Some auto parts stores that have code readers, can slear the readings. If they are valid, they will come back.
Old May 15, 2012 | 06:49 AM
RCsGX's Avatar
RCsGX
Remove the battery terminals or get a OBDII and reset it manually through the scanner. But if the problem still exists the code will come back.
Old May 16, 2012 | 05:04 PM
clubsport's Avatar
clubsport
the gas treatment must have increased the tank pressure and did something weird to the cap but anyway i just left the cap off for 15min and went back closed it tight and the lights were fixed... so before you buy a new cap just experiment... thanx all for your help...cs
Jwall
Performance
Mar 4, 2017 07:49 PM
MickeyS
GX - 2nd Gen (2010-2023)
Nov 14, 2012 05:43 AM
Daganl
Aug 9, 2011 11:48 AM
bob2200
RX - 1st Gen (1999-2003)
Jul 19, 2008 12:25 PM
mwbuck
Nov 26, 2004 01:47 AM
