Gx470 No Start
Old May 21, 2026 | 02:02 PM
stoshzack's Avatar
stoshzack
Default Gx470 No Start
Hi All -
Had a strange thing happen today with my 2003 GX470 with 190K. Was picking up kids and turned off the vehicle. Went to turn it on and nothing. Completely dead. Popped the hood and checked the connections to the battery. Everything was fine. Tried to start it, nothing. Embarrassed that I had held up the carpool line, went to start it again. It started right up. On the way home, the power flickered for a minute but engine did not shut off. Got home, tried to lock it, nothing - no power. Went back out later and it started right. Checked codes and had an unrelated ABS code. Checked battery with power load - it tested good.
Any thoughts?
Old May 21, 2026 | 02:44 PM
stoshzack's Avatar
stoshzack
Did some more digging. Ecu-b fuse and ECU-2b fuse maybe?
Old May 21, 2026 | 04:31 PM
stoshzack's Avatar
stoshzack
Well - those fuses were ok. I should add that it was 95 degrees here today.
Old May 22, 2026 | 05:13 AM
chiph9's Avatar
chiph9
Ground strap?
Has the truck always been in the South?
Chip H.
Old May 22, 2026 | 08:53 AM
ALAN553's Avatar
ALAN553
Alternator or serpentine belt?
Old May 23, 2026 | 04:27 PM
stoshzack's Avatar
stoshzack
Originally Posted by chiph9
Ground strap?
Chip H.
Cleaned all grounds. Still had issues. Rig is original from Virginia.
Maybe starter relay? Neutral safety switch? Went out today and it started 5 times in a row.
Old May 23, 2026 | 04:29 PM
stoshzack's Avatar
stoshzack
Definitely not the belt. Could be alternator.
alhybrid
GX - 2nd Gen (2010-2023)
Dec 6, 2020 09:39 AM
schwartzyd
Dec 4, 2017 05:25 PM
DZ08ISF
IS F (2008-2014)
12
Apr 9, 2014 12:05 AM
BearsLexus
RX - 1st Gen (1999-2003)
Oct 20, 2013 01:29 PM
sjlex
Mar 24, 2009 04:38 PM
