Fresh Leak
Old Nov 4, 2024 | 12:57 PM
Kinann's Avatar
Kinann
7th Gear
Default Fresh Leak
2006 GX470 189,000 miles.
Replaced battery and was idling 15 minutes to warm it up to relearn idle.
Stepped away and saw this leak underneath. It's oily, not antifreeze. leaking from bottom of radiator bracket. No evidence of leaking anywhere top side.
Power steering?
AC ?
Transcooler?
Oil has a light red color to it. No smell.
Old Nov 4, 2024 | 05:22 PM
tz693's Avatar
tz693
Tranny oil. Check the rust on tranny cooler lines
Old Nov 4, 2024 | 07:52 PM
Kinann's Avatar
Kinann
7th Gear
Where's the tranny cooler? In back of the main? I haven't removed any plastic yet.
Old Nov 5, 2024 | 02:43 PM
chiph9's Avatar
chiph9
Also think it's transmission fluid.
The cooler is in front next to the horns.
Chip H.
Old Nov 5, 2024 | 03:41 PM
Kinann's Avatar
Kinann
7th Gear
It's NOT the trans cooler, all dry. I did find a slight radiator leak. Tasted it, very bitter.
Trans cooler looking down at connections
Trans cooler front
Trans cooler front
Slight radiator leak
Old Nov 6, 2024 | 01:04 PM
chiph9's Avatar
chiph9
As a note, the transmission cooler is an auxiliary cooler (it comes with the tow package I think?).
The radiator also has a cooling loop for the transmission fluid. The connections are on the passenger side under the overflow tank.
So it could indeed be either coolant (normally pinkish or red) or transmission fluid (red).
When my radiator went bad it leaked on the driver's side, on the plastic end-cap.
For replacements, you can use the OEM of course. But people have also had good results with the Koyorad.
Chip H.
Yungbanshe
15
Jan 13, 2024 04:36 PM
18kWhNX
Hybrid Technology
Oct 23, 2022 10:35 PM
BillDwall
Mar 18, 2022 02:01 AM
colenzae
RX - 1st Gen (1999-2003)
Apr 12, 2017 08:23 PM
