Zero acceleration when pushing the pedal down
My accelerator pedal stopped responding. I get zero RPM increase when pushing the pedal all the way to the floor.
I checked the ETCS fuse and it was fine. Idle is fine. No acceleration or performance issues prior. No CEL. I dont have a scanner so not able to check any codes.
Any insight would be appreciated. Thanks
Try doing a computer reset. Disconnect the negative terminal on the battery, wait about 2 minutes, then reconnect with a minimum of sparks (if possible).
You will need to reset the auto-windows, etc. (see sticky about resetting power windows at top of the forum) afterwards.
Chip H.
Chip H.
I think you're going to have to get the codes read. Could be anything from the throttle position sensor to the throttle body actuator, to a transmission solenoid.
A generic reader (like AutoZone uses) should be able to identify those, as they're in the common OBD-II spec. But be prepared to step up to a Toyota/Lexus-specific reader.
Chip H.
Chip H.
