wireless door lock buzzer
Old May 26, 2023 | 04:27 AM
coreyinwp's Avatar
coreyinwp
10th Gear
Default wireless door lock buzzer
Can someone tell me where the wireless door lock buzzer is located in 09 Gx470? Mine is not working and I am hoping to replace or track down the wiring.
Thanks
Old May 26, 2023 | 07:39 AM
Davenlei's Avatar
Davenlei
You mean the piezo 'chirp' when locking and unlocking the door with the remote? I can't remember if it is a Techstream option but if so, are you sure that feature was not turned off? Those usually don't go bad since it is such a simple module. But to answer your question, I don't know where the piezo speaker is.
Old May 26, 2023 | 09:23 AM
coreyinwp's Avatar
coreyinwp
10th Gear
Yes I checked with a scanner and it is on and at max volume. I think a wire might have been chewed so I am trying to chase from the buzzer/chirper unit up...
Old May 26, 2023 | 11:02 AM
Davenlei's Avatar
Davenlei
Could it possibly be a fuse? I am just shooting in the dark for low hanging fruit...
Edit: I just read on ih8mud that the piezo is wrapped and under the master cylinder. I have not checked my car to confirm.
Some there reported the same issue and replaced the piezo to get it to make the chirp when locking/unlocking with the remote.
Old May 26, 2023 | 11:59 AM
coreyinwp's Avatar
coreyinwp
10th Gear
thanks for finding the info,,,I will take a look
Old May 28, 2023 | 05:04 PM
coreyinwp's Avatar
coreyinwp
10th Gear
Just a follow up
Based on Davelei post, I pulled the engine cover and traced the wires to the chirper. Sure enough I had a broken/chewed through wire. Spliced them up and sure enough I have chirps!
Thanks Dave for the info.
Abernoots
Oct 21, 2022 06:27 AM
BLK98GS3
Jun 3, 2012 07:25 AM
BobbyT
RX - 1st Gen (1999-2003)
26
Aug 12, 2011 11:37 AM
