HID Replaced, BUT THERES A PROBLEM...
Old Jan 27, 2010 | 09:13 AM
cknjohnny's Avatar
cknjohnny
Default HID Replaced, BUT THERES A PROBLEM...
i just replaced the d4s bulb to an 8k. bought it from xenonking.com the brand is McCulloch. everything went in ok and fired up good. but when i drive my passenger side headlight turns off. when i noticed that i went home and try figuring out why it turned off. so i turned the light off then on and it works fine. but sometimes it turns off and its getting to be annoying. can you guys tell me why its doing this? should i switch the bulb to the driver side and take the driver side to the passenger??? is it bc the replacement bulb? need ur opinons guys... thanks
Old Jan 27, 2010 | 09:39 AM
BinaryJay's Avatar
BinaryJay
If you do a search you'll find this seems to be a fairly common thing that starts happening when people use some of the less expensive off brand bulbs.
First thing to do is switch bulbs left to right and see if the problem moves with the bulb, or better yet put your old bulbs back in, but chances are the only thing that will fix it is to get different bulbs or stay with your old ones.
Old Jan 27, 2010 | 09:45 AM
whlkev's Avatar
whlkev
CL Folding 25,000
swap the bulbs to see if problems still exist and revert findings
Old Jan 27, 2010 | 10:01 AM
cknjohnny's Avatar
cknjohnny
ok will do. thanks guys
Old Jan 27, 2010 | 12:45 PM
passnu2's Avatar
passnu2
been there done that with the changing of sides. It will work and then do the same thing. Its the bulb and the quality of it. Best to scrap them and get a good set of HID bulbs.
Old Jan 27, 2010 | 01:29 PM
rominl's Avatar
rominl
exclusive matchup
i also tend to think it's the bulbs, but do swap to make sure it's not the ballast acting up
Old Jan 27, 2010 | 03:36 PM
bs0dxi's Avatar
bs0dxi
yea this has happened to me before. the others are right its probably just a bad bulb.
Old Jan 27, 2010 | 04:17 PM
BinaryJay's Avatar
BinaryJay
Common sense applies here.
I just changed something, and that something no longer works. What could it be? The something! Put it back the way it was.
It would be different if the bulbs had been working fine for months or years. By the way nice stealth edit.
Old Jan 27, 2010 | 10:59 PM
rominl's Avatar
rominl
exclusive matchup
well unless you break something else when changing something that can happen
Old Jan 28, 2010 | 12:35 PM
cknjohnny's Avatar
cknjohnny
hey guys thanks for the opinon. its the bulb bc i switched it side to side and it still acted up. so now i'm just waiting for my replacement. if they ever going to send it out to me. what a hasle.
Old Jan 28, 2010 | 05:07 PM
R.DUB's Avatar
R.DUB
get a diff brand that has been recommended here in the forums. Even though I had never heard of Garax brand before, I got Garax based on this forum. My Garax have been awesome!
You can learn a ton from others' experiences here.
good luck
EZLex
May 13, 2018 10:54 AM
Greer26
Dec 20, 2016 10:08 AM
GRZMNKY
Jan 6, 2012 09:14 AM
UNCGS06
Oct 11, 2010 10:19 AM
chnco
Dec 6, 2007 11:54 AM
