Need help or advice on what issue can be..ABS, VSC, VSC OFF lights on.
Need help or advice on what issue can be..ABS, VSC, VSC OFF lights on , 00 Gs300 139K drives fine and normal but the lights are bothering me and would like to fix it Also has Code P0135 and p0155 for o2? Not sure if this helps but car had 22inch wheels and i removed them and put stock ones.. New brakes and rotors allaround. I was told it may be the speed sensor. Anyone know what it may be? Any advice will be great
Thanks
Thanks
I found out that it's the throttle body that went bad on my Gs ..... Mine did the same thing then my gas paddle start acting funny but I found out it was the throttle body I don't know if it might work for yours
Thanks for your replies. I am searching the forums still a neewbie to the site, but yes my speedometer is working fine and throttle body as well. Would it be the abs sensor itself? Ill keep searching for diy methods before spending money on the wrong ways.
When I had these lights come on it was due to a bad alternator... I thought it was brakes/abs unit going bad but after searching on the forums I found someone who said it was due to a bad alternator. Sure enough I checked my alternator and it was bad, replaced the alternator and the lights never came back. Check.your alternator!!
Had my battery, alternator, and starter checked they seem to be fine. Still searching on this issue. Also the lights to my heated seat buttons dont light up and nor do they heat up.
Mine comes on and off and my car is dropped. I think imma check it tomorrow lol .. When I turn on my car, my warning lights don't light up where the vsc and abs lights are. My warning lights for my seatbelts wouldn't even flash.. I wonder if it's due to my car being dropped since stance coils don't have a brake line bracket and it's currently zip tied to the tube
i had this happen to me a couple of years ago on mine, all my lights came on dash,i had new battery still the same i had alternator reconditioned still the same so had new tentioner fitted still the same, lights where off till i did a hard lock on steering wheel then they came on and stayed on till you switched off, at the end i found the problem? which you have to look very closely,with engine running and a/c and lights and radio on get someone to keep turning steering wheel fully lock both ways and you look under bonnet at the main belt that goes around crank pully, on hard lock the belts stops turning it was my crank pully had split apart
Imma give that a shot.. Or maybe just leave my battery unplugged for 24 hours
Yeap. I bought my gs4 and the vsc light wasnt working... i took the dash out and saw that those 3 light bulbs were actually taken out of the dash hmmm. i had some spares put them in and boom all those lights are on. well wtf? i was tweaking at this point and sat and thought about it. all these lights deal with wheel speed of some sort so i thought maybe speed sensor? i went around and checked all 4. all looked replaced and greased up. but the front right sensor was actually unplugged. plugged it in and off went the lights the only thing i can think of is that they replaced the sensors and forgot to plug it back in thus getting pissed at the lights and just taking them out. or since its a california car and never really need vsc or abs they left it unplugged to bypass turning the vsc off every time they got in the car. to be honest i turn mine off every time im in the car hahah. but yea definetly check the connections or worst comes to worse you may have to replace the speed sensor. im not sure the cost of these but i cant imagine it costing that much.
Found it.. I will try this later tonight or tomorrow. Been lazy all day lol imm try to reset first since I dropped my car lol .. I'm on coilovers now and I use to be on bags and lighs came on for both suspension types. I wonder what would've happened if I left it all stock lol
Here's directions on how to reset the light (post #9)
https://www.clublexus.com/forums/gs-...-light-on.html
Here's the PDF
https://www.clublexus.com/forums/att...-on-di-412.pdf
Here's the PDF
mandyfig
06-20-22 04:29 PM
treimche
02-04-11 04:23 PM
