I've read a few places that they can and when i look at pictures of the coilovers they look exactly the same. So can they fit and if they do does it require any modification to make them work properly? Any and all help is appreciated
so i can buy any mk4 coilover for my car and it will bolt in without any modifacation cause i already found a set of stances for cheap
Yes, you can!
The car is going to sit pretty low with supra coilovers. You cant adjust them quite as much as you would be able to do on a supra, BUT they do bolt up and you wont have any problems with them. They will make your car look sick!
WTF.... the rear is different.... I had TEINs and they are different in the rear; not a straight bolt on issue....
Quote:
let me know how you make out with themOriginally Posted by 147noob
Stances here i come!!!
Quote:
i dont know if i should buy them cause i dont know if they'll work does anyone on here currently have a a80 coilover on there car and can tell how hard was it to put on cause from what i can tell they look all the sameOriginally Posted by vtec-this
me and my buddy where gonna trade shocks for coilovers i have a 94 gs300 and he has a 92 sc300 and im currently running stock struts on df210 springs and he is running tein coilovers from a mk4 supra and well my issue was that the coilovers will definetly botl on and will sit lower but you can always adjust you wont have a problem w the bolt on its if u decide to raise your car its not gonna go as high as if you had 147 coilovers but who gets coilovers if their not gonna slam so im getting my tein flex that came from a mk4 to a sc300 onto now my 147, but the bs is the stock 147 struts wont bolt onto his sc300 cuz the rear are way too long so im stuck buying stock struts from an sc300 and then switching the lowerings springs over and then we can trade the struts for coilovers so to answer the quest yes mk4 will bold directly to a 147 chassy they just wont go as high as if you were to get actual 147 coils.
Yeah someone that has done this needs to adjust to max height and take photos!
