Broken intake actuator, worth replacing?
Last week I had my battery replaced under warranty. I just discovered two days ago while cleaning my engine bay that they broke the actuator that controls the flap for the intake. It looks like it’s the plastic cap (filter?) for the actuator. Since I moved its location for the RR Racing intake kit, I’m assuming they will say I modified that part by moving its location for aftermarket parts and so they won’t cover it. I have the intake and a mid pipe and they haven’t said anything about warranty yet but I don’t necessarily want to push it.
What are your thoughts? The actuator still works fine but does anybody know if I can find a replacement for that plastic cap? I looked at a few parts sites but couldn’t find anything.
thanks
thanks
EDIT: after reading RTIS250’s and lobuxracer’s comments and thinking about it again, I can’t 100% say they did it so changing my overreaction
No but I could go to a toyota dealership instead, at least I won't have to deal with them detailing my car when i tell them not to and ruining the finish on my wheels.
I was planning on refinishing them to another color anyways in a year or two so i wasn't as upset but still annoying. Now with this latest issue I just don't know if I can trust those guys in the shop with anything important if they can't even replace a battery correctly.
jonez (05-16-19)
Tech Info Resource
Third, it's just a muffler for when the solenoid opens and bleeds off the air pressure in the diaphragm. You are concerned because it doesn't look the same?
I would totally get it if you were certain the service tech broke it, or if it were the nipple on the diaphragm and the actuator really was broken, but this is 100% cosmetic. If you remove it completely, you might get a sound like a BOV...
I have some spare VSVs laying around with mufflers on them. If you really want one PM me, I'll mail it to you.
jonez (05-16-19)
To get the battery out from that side of the car you have to hoist it over that point.
As for talking to my service provider, I figured I would ask here what it is and if it’s even worth replacing before I go back to them. As I said in my first post, I have the RR Racing heat shield installed where it normally would be so I want to avoid having to put it all back to stock if the broken plastic piece isn’t going to impact anything.
