GSF clunks when shifting to drive from park.
I've had this issue ever since I got the car. Has 11k miles on it but yesterday it did something totally strange.
I haven't driven the car for a week and it was in my garage. I attempted to shift into reverse to back out and it went into reverse but it was like I was putting my foot fully on the brake without me putting my foot on the brake. I pressed on the accelerator and it just felt stuck. I was confused and put it into park and could feel it going into park. I tried it again and no go but I pressed on the accelerator even further and it finally broke free and could hear a loud clunk sound and all was well. I had to quickly press on the brake because the car shot back like 5 feet ha...
Before that I would always get a clunk sound probably by the transmission and differential when shifting from park to drive. Also, when I park the car, there isn't a clunk sound when going from drive to park but there is a clunk when you park and let go of the brake and the car moves forward a bit or backwards. Can any expert mechanics offer some input? I'm thinking u joints or something with the differential?
Car is under warranty but I just moved out to middle of nowhere Illinois and nearest Lexus is friggin 3 hours away.......
Thanks!
Thanks!
Thanks!
Thanks!
Other than this, car has been great. I could complain that the ventilated seats are weak, but eh I’ll live.
I have about 5K miles, issue probably started around 3k miles id say.
That happens to me, but only when I wash my car and immediately park it. Once the rotors/calipers dry, the water run off forms some surface rust and will seize your brakes that you have to "break" out of and the car will clunk/lunge when you press on the accelerator.
I always try to drive a block of two to work out and fling out the excess water before parking it after a wash in the driveway.
Long term parking could do that as well, but I haven't experienced it on this car.
Tech Info Resource
Sounds possible the brakes are sticking, but I would also have the transmission fluid level checked on the next service. AA80E are known for having issues of many kinds if the fluid level is low, even just a little bit. There is a massive thread stickied in the IS F forum about changing the gearbox fluid that talks about this.
TrevorR (08-04-18)
Well... This ended up being the issue. Nice call! I made the 2 1/2 trip to Lexus and they heard the sound and checked transmission fluid and noted that it was low.
Now my concern is if my transmission is burning fluid...
Like I said before, the sound does not at all come from the wheels. The sound is coming from the transmission/driveshaft area.
designo (08-06-18)
Tech Info Resource
CobraGSF
GS F (2016-present)
12-01-16 05:43 AM
qewani1
02-27-09 06:26 PM
