ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   GS F (2016-present) (https://www.clublexus.com/forums/gs-f-2016-present-283/)
-   -   Car Wont DO A BURNOUT (https://www.clublexus.com/forums/gs-f-2016-present/870618-car-wont-do-a-burnout.html)
gsfdream 10-16-17 01:19 PM
Is there any way to either pull a fuse of some special trick with the traction control to be able to disable the system to allow me to do a standing burnout?
Every time i try it cuts power with a message popping out saying Accelerator and brake pressed at same time.
Is there a fuse we can pull to disable this?
yardie876 10-16-17 01:27 PM
Obvious question... have you tried in expert mode?
flowrider 10-16-17 01:45 PM
https://www.clublexus.com/forums/rc-...g-burnout.html
https://www.clublexus.com/forums/rc-...f-burnout.html
https://www.clublexus.com/forums/rc-...-possible.html
Lou
mjeds 10-16-17 01:47 PM
there is a specific procedure.
post #28 https://www.clublexus.com/forums/rc-...g-burnout.html
first put the car into manual, then turn to sport+, then press and hold traction control, don't go into expert, go past expert into all off mode.
do it out of sequence and it won't roast the tires.
gsfdream 10-17-17 07:47 AM
cool will try the sport+ traction off and manual mode
5280Fsport 12-28-17 02:56 PM
Did this work?
NotnFsport 12-28-17 09:16 PM
It did not work for me. I even tried up up down down left right left right b a start and still nothing...but seriously I tried and tried and it doesnt work.
gsfdream 01-02-18 10:16 AM
Originally Posted by 5280Fsport (Post 10066184)
Did this work?
no the only way it works is sport plus then manual and then hit traction control once and it goes into expert mode this way it lets you do a burn out but it automatically upshifts into second gear which i dont get since its in manual mode.
GS3Tek 01-03-18 09:13 AM
Good one:D:thumbup:
