740 hp GSF?
Old 05-25-17, 01:05 AM
aginnt
aginnt's Avatar
Default 740 hp GSF?
I am a happy GS F owner for over a year but, I could always use more power.
I found this video online of a 740+ hp GS F without turbos. Does anyone have any idea how they got these power numbers?
The video looks real because the top speed is higher than the car out-of-the-box.
This GS F appears to be in the mid 3 second range to 60, which would be competitive against the next gen M5 and E63.
I also heard that most exhaust kits for the GS F at 30 whp+ because Lexus tuned the exhaust system conservatively.
aginnt is offline
Old 05-25-17, 08:27 AM
Meraki Autoworks
Your #1 Lexus Vendor
Meraki Autoworks's Avatar
Think its sped up.. The beeps sound off. Could be on a dyno too.
-Josh
__________________
Your #1 Dealer for Aftermarket Performance Products
Orange County, CA
Text/Call: 213 394 2886
Meraki Autoworks is offline
Old 05-25-17, 10:25 AM
E90076
E90076's Avatar
I dunno...seems impossible to get to 740 hp NA.
E90076 is offline
Old 05-25-17, 01:10 PM
danwlee
danwlee's Avatar
There's a few NA motors with 700+ hp... but they also have 4 more cylinders.
danwlee is offline
Old 05-25-17, 03:16 PM
ISFPOWER
ISFPOWER's Avatar
i wouldn't trust video where the description says it goes from the stock 500hp to 740hp. 500hp huh?
ISFPOWER is offline
Old 05-25-17, 06:10 PM
plex
1UZFE/2JZGTE
plex's Avatar
I call BS
plex is offline
Old 05-25-17, 06:54 PM
mjeds
mjeds's Avatar
mjeds is offline
finny76 (06-08-17)
Old 05-25-17, 09:14 PM
Stormryu
Stormryu's Avatar
Without a turbo, without a super charger and without some type of hybrid setup? I can't imagine any N/A 8 cylinder engine getting that. As someone else said, need to add on more cylinders to get that of at least that is what I believe.
Man it's crazy how the world is changing. 300 hp used to be a standard. Then 400 then 500 then ~600 in a sedan that is the CTS V. Bmw is putting out their new M5 with ~600hp. Makes me wonder how much more HP #s will increase. Of course competition influences this, but just as general question.
Stormryu is offline
Old 05-26-17, 04:07 PM
Stormryu
Stormryu's Avatar
Originally Posted by kitabel
300 hp was 1955.
Right. State examples, cause I'm mostly seeing ~150 HP for the time
Stormryu is offline
Old 05-26-17, 05:30 PM
plex
1UZFE/2JZGTE
plex's Avatar
Maybe he meant 1995.
plex is offline
Old 05-26-17, 09:02 PM
knshro13
knshro13's Avatar
The sped up BEEP should give it away.
knshro13 is offline
Old 05-28-17, 02:27 PM
Vitveet
Vitveet's Avatar
The beeps sound normal honestly. Beeps right before the shift/redline.
Not saying by any means that that F is 700 HP, Lol, but just that the beeps sound normal.
V.
Vitveet is offline
Old 05-31-17, 02:07 PM
leahb16GSF
leahb16GSF's Avatar
I think its BS, unless its in front of me, I don't believe it. Not that it is impossible, but I don't think this is legit. If it were supercharged or turbo'd, much more believable. Either way, to push out that kind of HP, you better have some serious cash aside.
leahb16GSF is offline
Old 06-01-17, 01:37 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,838 Likes on 2,327 Posts
What do you suppose "Chrysler 300" means?
Yes, that.
It means it made 300 hp on a crankshaft dyno with all the accessories removed/disconnected as was standard back in the day this car was popular. Nothing like the 300 hp we see commonly on a chassis dyno with all accessories at least spinning and all driveline losses included. The old school big inch engines were pretty crude in a lot of ways. I remember helping my dad build 426 Hemis for 1/2 mile dirt track racing in the early 70's. Pretty agricultural and killed by the rules when you couldn't put a 1050 Holley on top of it anymore. He still loves those engines, but he's built way more powerful small block Chevrolets since then.
lobuxracer is offline
Stormryu (06-01-17)
Old 06-01-17, 01:49 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
The clip shows nothing on the screen but the speedo, no dyno, no ET slip, no trap speed. Why believe this?
Is it possible to take an already highly-tuned engine and raise the NA output by 58% (740 / 467)?
Perhaps, just R&R everything in the engine (pistons, rods, crank, main caps), bore it 2mm to 96mm, stroke it from 89.5 to 95.5mm (5,530cc), raise the compression to 15:1, run M100, 120mm TB, larger valves + full flow bench porting, tuned open exhaust, and enough cam duration to raise the peak power to 9,000 RPM (and no power until 4,000).
$30,000? $40,000? Perhaps 2 years in development?
Stroke is death if you want big NA numbers because it lowers red line, and you need rpm to make power. If you choose to increase stroke, service life drops exponentially and the piston kinematics of this engine aren't all that great with the current stroke and rod length.
You could get 3000 hp out of 5 liters for about one F1 race if you wanted, spinning at 18,000 rpm or so. It's all about moving air and not overstressing the mechanical components. It surely won't happen with the 2UR remaining a street worthy engine even if you grafted the 10 speed gearbox to it.
Quick Reply: 740 hp GSF?
