How to lighten Steering effort?
Hi I have a Lexus GS 350 F sport the steering is pretty stiff when turning at low speeds in both eco and normal mode.
I went ahead and did a wheel alignment, they did found it was a little off in terms of the toeing of the front and rear wheels. Camber had no misalignment in fact it is in perfect alignment. It did help a little bit with the steering responsiveness. However it is still pretty stiff turning at intersections.
Please help
Please help
Please help
Please help
I guess that you know the steering gets even heavier in the Sport mode compared to ECO or Normal.
I'd keep some free-weights in the car for when you're at a light. I find it quite easy to turn in Normal and Eco mode. Do keep in mind that wider tires provide a more direct steering feel and increase the resistance slightly. Probably not a good idea but 225 tires on front could change the feel?
There is a **** under the car to adjust steering weight, but it only appears once in a blue moon. Get in the habit of putting both palms flat on the ground, and lower yourself closer to the ground to check if it's there. If not, then push yourself back up, but make sure to do this with your knees off the ground to keep your trousers clean. Do this daily for a few weeks.
jonathancl (04-23-19)
LOL. But on a more serious side, I found the steering in the GS to require very little effort, almost too effortless. I wanted more stiffness and a tighter response. The steering on the 03 Infiniti G35 and 02 Toyota Sequoia, I’ve been driving the last decade and a half are definitely on the stiffer side.
A PS fluid flush may improve the feel, especially if you have miles.
Cheap, worn or underinflated tires can drastically change steering feel.
Please help
Please help
However, our cars have speed sensitive steering so at low speeds, the steering should be fairly light. It is possible that the power steering or sensor are malfunctioning if you feel its overly difficult to turn at low speeds. Steering is affected by a lof of things (tires, wheels, suspension, sensors, road condition) so have it checked out. Too many factors to give a definite but it sounds like you're on the right track starting with your alignment...
CouveGS (04-25-19)
What kind of car are you comparing it to? If you are comparing it to an old school ES or something, the steering is never going to be THAT soft, that's just the way it is.
-Mike
-Mike
