Help with Steering/Suspension component.
Old 03-21-19, 09:47 AM
yelloiroc
yelloiroc's Avatar
Default Help with Steering/Suspension component.
If anyone is able I need some help identifying a suspension component and if it needs to be replaced or not.
I searched through the forums for an answer but as I'm not sure what the piece is called I had a tough time locating an answer.
I was replacing my pads/rotors yesterday and noticed what appeared to be a very worn bushing on the lower control arm. Looking through some parts diagrams i was not able to find this specific piece, and unfortunately, my wheels are back on and I forgot to a take a pic. Hopefully, DIY Dan does not mind that I plucked a frame from one of his videos to show the part. If anyone has any insight it would be much appreciated.
Part is circled.
Old 03-21-19, 12:23 PM
rog1206
rog1206's Avatar
Is your car an AWD? This looks like the lower part that attaches to the front strut of the awd models.
https://www.lexussouthatlantaparts.c...​​
yelloiroc (03-21-19)
Old 03-21-19, 01:31 PM
yelloiroc
yelloiroc's Avatar
Sorry about that I should have included some more specifics. Yes, it's an AWD Car.
That does look like it. The bolt part of that shaft looks like its just floating in the control arm. I'm shocked to see no bushing but relieved that it hasn't rotted away.
Now that this mystery is solved, I have to now figure out the source of the clunking in the back of the car when pulling away from a stop. At first i thought it was a golf ball rolling around in the spare tire are, but that wasn't the case.
Old 03-21-19, 02:12 PM
Knucklebus
Knucklebus's Avatar
I'd call that the 84514 (right) or 84515 (left) and it is called the BRACKET, FRONT SHOCK ABSORBER, LOWER RIGHT. BRACKET SUB-ASSY, FR.
Does it make noise and can you get movement out of it within the lower control arm? The one in the image appears to have a significant amount of fore/aft clearance.
yelloiroc (03-22-19)
Old 03-22-19, 08:19 AM
yelloiroc
yelloiroc's Avatar
No movement using a moderate amount of force. The photo I included in my original post was not my vehicle, but an image I found to illustrate the component in question. The condition of mine looks pretty similar.
Old 03-22-19, 09:56 PM
er34
er34's Avatar
Common clunk that "seems" to come from the back could actually be the moon roof. Changing the seal fixes this problem. There is a pretty long thread about this.
​https://www.clublexus.com/forums/gs-4th-gen-2013-present/872207-moonroof-rattling-clunking-here-s-the-fix.html​​​​​​
yelloiroc (03-23-19)
Old 03-23-19, 07:03 AM
yelloiroc
yelloiroc's Avatar
Thanks for that i'll take a look. I dont hear much wind noise from the sunroof but ill move it around and check for any play. The sound i hear most often seems likes its coming from the passenger side rear of the car. I'm almost ready to ride in the trunk while someone drives to isolate it.
chrisvo95
02-27-18 12:07 PM
rodney978
Suspension and Brakes
09-05-17 10:01 AM
Celsius
03-22-15 09:09 PM
B.Diddy
Suspension
12-21-07 07:29 AM
SeattleGS400
12-17-03 01:03 PM
Quick Reply: Help with Steering/Suspension component.
