Key Card for GS
Key Card for GS
I spoke with a dealership on getting a working key card for the GS350 but was told it did not exist.
The key card for the GSF is 89904-30L50 (+ 69515-30350 master key).
Has anyone tried swapping out the radio on these unit with an aftermarket solution to make it work?
Wanted to get some input before I started experimenting. Thanks.
i think the IS forums had said this will work, if i find the thread ill copy it here
eddie420 (02-18-19)
I thought the card existed just not for the refreshed years?
*edit* nvm I saw some old posts from lobuxracer about it only being the korean spec one...need to figure out if the gsf one will work then, parts number for gsf card is: 89904-30L50. Need someone at the dealership to order one and test it out or find out some other way
The following 4 users liked this post by baconRx:
Awesome! how long did it take for the dealer to set it up?
30-45 minutes. I'm was pleasantly surprised it worked and it came with the F logo on the key.
Just looked up the part number
https://www.lexuspartsnow.com/parts/...904-30l50.html
its the GSF key and it works
I really like the weight to it
Also, they often mistake my car as a GSF at the service bay cause I have the rims... not sure if they just started off with the GSF and it ended up working or what
VA75067 (02-25-19)
The following 5 users liked this post by Cwang:
AsianxWu (02-26-19),
kode3 (03-07-19),
onizukhoa (11-06-23),
promethus7 (02-26-19),
TwentyTen (03-07-19)
I have never seen this. Does this replicate all keyless entry and start functions of the regular key fob? So essentially the regular key fob without buttons? And the point of this is to just carry something slimmer?
pretty much. theres a slot for a thin physical key you also can buy just in case the battery dies but you don't have to buy it if you're really cheap. I got it cause I don't carry keys with my so I always just had the fob in the case, my wallet, and phone to grab whenever i leave, but now its just in my wallet. I never used the buttons so its nice to have one less thing to not have to run around the house looking for cause I leave left the fob in a different pair of pants or its hidden under something
