Wiper sticking(don't think it's relay related)
Hey Clubbers,
When it's raining but only lightly, my wipers come on. They seem to shudder across the screen, occasionally with enough force to switch to the winter mode. When there is sufficient water, there is no issue.
I'm aware of faulty relays causing issues but I assumed that factor wouldn't differentiate between wet and dry.
I filmed it dry, however a similar effect is witnessed during a sprinkle
Has anyone had this issue?
They only mount 1 way due to the way they snap in, however it's possible the car might want the rubber inside to be reversed. Of the 2 sides of the rubber, the side pushing towards the roof is 90 degrees(sorry if non-US unit it traps me every time) and the side pushing back down towards the bonnet is angled at something like 50 degrees.
Make sure the bolts on the arms are completely tightened.
When I spray the washer fluid it works perfectly, until it gets dry and snaps up into winter mode due to the torque of the motors.
I gave it a really good scrub a couple of times. Maybe there's rainx or something nasty on it...might try alcohol or something else stronger than soapy water and Windex?
I definitely wouldn't let it run like that because it's going to either shred the gears or wear down the motor. Spray washer fluid if you have to.
How old are your inserts?
I usually clay bar my windshield once a year. It leaves the surface buttery smooth and the wipers work better. In light rain, I even turn off the auto wipers because the water just glides off.
