Anyone running these 19" forged F sport rims?
https://www.mylparts.com/oem-parts/l...ont-ptr4553081
Part number is PTR45-53081 .
I am thinking if I can get 4 of the 19" x 8", I can use this on an AWD GS just fine, with the right lugs...
Only confusing thing is the colors for these wheels. I'm pretty sure this is the PN for the darker gray
wheels. There's another set of these that looks more like silver but I can't find the damned PN.
Somewhere I read the weight of these is like 21 lbs... and they're forged!
-Mike
-Mike
Boomin (06-28-19)
drgrant (06-24-18)
Still trying to get all the cake together to make it happen, I discovered the wheels aren't that expensive most dealers have them for like $500 ea but a bunch of other places online sell for less than that. I want to put a set of Michelin PS4S on them at the same time so its kind of a big nut to crack. It would have been done by now but I had the choice of "Vacation in CA because I haven't been in like 2 years" or a set of wheels.
If you dig around on the forum someone here has a similar set of wheels on an IS, same design but like 18".
-Mike
-Mike
drgrant (10-17-18)
Those P235/40/R19 tires on there?
Which lug kit did you end up using? (color, vendor?)
-Mike
-Mike
This is an AWD GS with 19x8 all around. The tires are P235/40/R19. I used the PTR27-53090 lug kit (sslexus on eBay). I believe the offset is +40. Everything mounts up great with no problems.
Try this. Lexus parts now install doc
I'm running the New Full-Face Silver on my 2014 GS 350 F-Sport and they look great.
That procedure is pretty slick -- is there a place to get more like that, for other repairs / work?
thanks for the info! now I have no idea how wheel fitment works anymore
stock GS wheels are 19x8 +35, and I thought +40 wouldn't clear the front brakes...
Like I said no problems. Clears brakes and everything. Just make sure you get the right wheel kit if you go the Lexus F Sport route as there are a few kits depending on the application and whether your car is AWD or RWD.
I finally did this.... car is dirty, so don't judge too harshly.... lmao... Tires are P245/40R19 Michelin Pilot Sport 4S (PS4S). The fatter tires look a little better than the P235s... still a lot of wheel gap, but much better looking, imho.
-Mike
-Mike
The following 3 users liked this post by drgrant:
Now the fun part on these, where to set pressure? Been running the PS4S at 36 front and 37 rear cold.... wondering if I should go lower? They ride hard compared to the old tires, but these things are grippy as hell.
-Mike
-Mike
Looks good!
Where did you end up buying from? I've been looking all over for a single replacement 19x8 for my set and dealer quoted me $650 per. Ebay seems to only have 19x9's. I've seen a few online retailers with them, but not sure how reputable they are while others are clearly re-creations.
