'13 GS350 F Sport - Pics
#46
Today I put 20mm spacers on the front and it made it so much better, I put 20mm on the rear but it was too much. So I pulled them off and going to get some 15mm and see how they look.
Stock fitment front
Front with 20mm spacer
Rear stock fit
Rear with 20mm spacer
Rear with 20mm spacer no
Stock fitment front
Rear stock fit
#50
Goodness... I am going to end up doing a lot of things you are doing. Are you going to try the tape the carbon spoiler came with you do you not trust it? And the spacers...where can I get a set of those?? Fits so much better up front. curious to see what the 15mm looks like in the rear.
#51
No, I'm going to see if I can get the stuff from the factory. The stock spoiler has a piece of foam that goes along the outside that seals it. Then there are patches of two sided tape that hold it down along with the plastic anchors and 2 screws. If I can't get the factory stuff I'll find a way to get some.
#53
#54
This is lights on only in daylight. Tinted on left stock on right.
This is brakes on in day time. Tinted on left stock on right.
#56
Put 15mm spacers on the rear tonight. I tried 20mm the other day and it was too much for me. This is still a little much for me, I think 10-12mm, but I'm done swapping these out. It's not out far enough to bother me. I have some more parts coming that should help hide the tire. Anywhere here is stock vs the spacers...also disregard the dirtyness, it rained bad last night and I had to drive through a field . Also it seems the little bit of spacing out has made the tire more vertical as you can see it was leaning in a bit.
#59
Had the car 2 weeks now, so far I have had it tinted, I lowered it, carbon plate frame, and added black lug nuts. First wash and wax last night so I decided to take a few pics before it got dirty and before the next round of modifications come. I guess this could serve as my build thread to show the progress.
GS350 Pics
GS350 Pics
jonathancl (09-29-18)
#60
