Moonroof rattling / clunking? Here’s the fix!
Old 11-14-17, 04:42 AM
OneFunGS
OneFunGS's Avatar
I didnt have an indentation on mine at all. I did, however, have a small drain slit and I installed that at the back. I am now concerned that it should be at the front. Anyone checking your seal..can you see a small slit cut in the dead center of the seal on the back or front? Can you tell me where it is located on your stock car?
Thanks
Old 11-14-17, 06:30 AM
protocol71
protocol71's Avatar
Thanks
my new one had the exact same indentation/slit as the one it replaced, so yes it does have that. i also ordered mine from the same link provided earlier in the post. since the slit was only on the rear i installed it the same way.
Old 11-14-17, 07:01 AM
OneFunGS
OneFunGS's Avatar
whew. okay. I installed it correctly then lol thanks!!
Old 11-14-17, 07:39 AM
CottageChz
CottageChz's Avatar
Just ordered my new seal last night. I wanted to replace my seal because of wind noise, but everyone else in here is talking about clunking. Does the clunking you guys are talking about sound like it is coming from way in the back of the car, like the C pillar area? I have some clunking back there, and if the sunroof seal fixes that too I will be so happy! I suppose it is possible that the sunroof clunks and echoes around in the gap between the headliner and the roof, making it sound like it is coming from the back of the vehicle.
Old 11-14-17, 07:54 AM
OneFunGS
OneFunGS's Avatar
I replaced mine because of wind noise. This was just a much easier way to do it than take the whole glass out.
Old 11-14-17, 08:03 AM
protocol71
protocol71's Avatar
To me it doesnt even sound like its the sunroof but something further back but i think the clunk resonates all around. easy test is to just open the sunroof all the way back and then see if the rattling/clunking goes away when driving. if it does this will fix the issue.
The following 2 users liked this post by protocol71:
greys0uled (08-26-22), thisguy_06 (07-11-19)
Old 11-14-17, 08:11 AM
CottageChz
CottageChz's Avatar
Good deal, thanks. It's been pretty cold here, so I haven't been opening the sunroof, but I've been wanting to do that test. My clunking seems to come and go.
Old 11-14-17, 08:57 AM
yardie876
yardie876's Avatar
I replaced it for both issues. The clunking sounds like it’s coming from somewhere in the rear. I found it by placing my hand on the sunroof glass and moving it around, which allowed me to replicate it.
Now no noise and no clunking! Best $50 I’ve spent on this car lol.
Old 11-14-17, 09:38 AM
CottageChz
CottageChz's Avatar
Originally Posted by yardie876
I replaced it for both issues. The clunking sounds like it €™s coming from somewhere in the rear. I found it by placing my hand on the sunroof glass and moving it around, which allowed me to replicate it.
Now no noise and no clunking! Best $50 I €™ve spent on this car lol.
Awesome! Sounds like the same clunking I have. So excited to replace the seal and fix both these issues!
Old 11-17-17, 01:52 PM
MustangSal
MustangSal's Avatar
So my dealer solved my clunk by cleaning and lubricating the gasket. At least, that’s what the service report says. And you know what, it worked. Dead quiet.
Old 11-18-17, 05:19 AM
Spideyman1
Spideyman1's Avatar
In my case, yes, the clunking noise sounded almost like the rear suspension. I also has wind noise, both are now gone with the new sunroof gasket!
mtucci3 (01-22-22)
Old 12-03-17, 07:24 AM
mrcleean
mrcleean's Avatar
Thank you to the op for posting this as it was much easier to remove only the two front screws. I have a 2014 that started rattling recently. It sounded like it was coming from the trunk area. Figured I would give this a shot since it would cost less than $50. Sure enough, after replacing the seal, rattle gone! Btw, I purchased mine from a Toyota dealership for a little bit less. Same part number.
https://www.oemtoyotaparts4less.com/oem-parts/toyota-weatherstrip-6325130100
microsup (12-13-17)
Old 12-04-17, 12:18 AM
peasodos
peasodos's Avatar
Received 2,226 Likes on 1,450 Posts
I think I have the slit installed correctly in the rear, but no indentation exposed on the top. I might have installed the seal upside down, if that's even possible. Time to take it off and reinstall with the indentation exposed on the back rear.
Also good idea to clean the seal and apply some silicone grease.
Old 12-04-17, 03:56 AM
mrcleean
mrcleean's Avatar
The way the seal is designed, it would be very difficult if not impossible to install it upside down. As long as the slit is in the rear and the dots are at each corner, you should be good.
Old 12-04-17, 05:25 AM
OneFunGS
OneFunGS's Avatar
I dont think the new part has the indentation as I was looking for it as well last month and didnt see it. I have the slit in the rear and you cannot install it upside down lol
Quick Reply: Moonroof rattling / clunking? Here’s the fix!
