Daylight Saving Time - Clock & NAV
Old 11-05-17, 10:14 AM
bclexus
bclexus's Avatar
Received 1,994 Likes on 1,417 Posts
Lightbulb Daylight Saving Time - Clock & NAV
Daylight Saving Time officially ended this morning at 2:00 AM. Don't forget that you have two (2) changes to make to your Lexus - (1) setting the Lexus analog dash clock back one hour, and (2) turning 'Off' the DST for the Navigation system. In the past, many owners were unaware that the Navigation system did not automatically change to, and from, DST.
(1) Change your Lexus analog dash clock by setting the time back one hour.
(2) Turn 'Off' the DST for the Navigation system. To turn 'Off' DST in the NAV system, go to Menu > Setup > General > System Time > Daylight Saving Time > Off > Save
With the correct time setup for your car's General System Time - it allows the Navigation system to provide an accurate Estimated Arrival Time to your destination...
Note: This 'On' and 'Off' Daylight Saving Time change is made in the General setup - not the Navigation setup.
Hope you enjoyed the extra hour of sleep!
The following 4 users liked this post by bclexus:
96SC4 (11-05-17), jkeller (11-10-17), OneFunGS (11-05-17), viperr (11-05-17)
Old 11-05-17, 12:39 PM
jdpdata
jdpdata's Avatar
Thanks for reminder. Why can't the NAV system update time automatically? It's getting GPS data, why can't it determine local time per car's location?
The following 2 users liked this post by jdpdata:
jkeller (11-10-17), jonathancl (11-10-17)
Old 11-05-17, 03:03 PM
shurik74
shurik74's Avatar
Thanks for reminder OP... What the point to change Navi? I think analog clock is enough IMO...
Old 11-05-17, 05:58 PM
bclexus
bclexus's Avatar
I guess with all the different areas of the country that the vehicle 'could' be used in - some going to DST and others not, some living near a border state that differs from their own state, etc. Lexus probably felt it was best to just have the owner make a simple change instead of it changing automatically with GPS data. Lots of sophisticated electronics including GPS units do not automatically make the DST change.
The only point in changing the NAV would be to have the correct estimated time of arrival when using the car's NAV system. If you never use the Lexus NAV system then there's no need to change it...and there's no need to even have the onboard NAV system. It's kind like having a filthy engine bay that nobody ever sees - some people like to keep it reasonable clean and others could care less. Maybe you could care less about the Lexus NAV system...even though it only take a few clicks to set it correctly. What's the point in not changing it?
Old 11-05-17, 07:00 PM
dchar
dchar's Avatar
In 2016MY+, the nav and analog can automatically change using GPS data (if setting turned on). I think you just need to drive outside for a bit.
Old 11-05-17, 07:24 PM
bclexus
bclexus's Avatar
Thanks! Yes, I believe Lexus did change it in model year 2016 so the NAV and analog dash clock works together and changes automatically from what I'm told. I should have said the change is needed to be done manually for the 2013, 2014 and 2015 model years.
Old 11-07-17, 01:29 PM
microsup
microsup's Avatar
I have 2015 and dashboard clock did not change automatically. I had to change it manually. Will check the nav clock if it changed automatically.
checked it, and it does change multimedia time automaticaly and doesn't the clock.
Old 11-07-17, 01:45 PM
JDR76
JDR76's Avatar
Received 1,603 Likes on 1,021 Posts
It doesn't change automatically on the 15s. I had to go in and turn DST off.
Old 11-07-17, 07:14 PM
modad
modad's Avatar
I got tired of waiting for my '16 to change and finally went in the menu and turned off the Daylight Savings Time so the clock would be right. If it does it automatically, it sure does take it's sweet time to do so..... even thought I had it set to change by GPS!
Old 11-07-17, 07:21 PM
bclexus
bclexus's Avatar
Maybe it was confused by your location. Doesn't most of Arizona not have Daylight Saving Time?
Old 11-07-17, 07:25 PM
modad
modad's Avatar
Haha! Bc, I wish I had a dollar for every time someone though my address state AR was Arizona.... It's Arkansas
Old 11-08-17, 06:37 AM
rjm
rjm's Avatar
Thanks BC. Great reminder. Please remember to remind me next year too because I will forget all about that again.
Old 11-08-17, 07:53 AM
bclexus
bclexus's Avatar
Sorry! I knew that...
I guess I was just thinking too deeply into wondering why your NAV and clock didn't change automatically and just jumped over my own knwledge.
Old 11-08-17, 08:46 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
I don't think my 2017 RC nav can change itself, I had to do it manually.
Old 11-08-17, 08:53 AM
JDR76
JDR76's Avatar
The RC didn't get that new nav until the 2018 MY. So your 17 RC would have the same version as the 15 GS.
Quick Reply: Daylight Saving Time - Clock & NAV
