Soft brakes, need advise
I have my 2015 GS350 F-Sport AWD for over a month and I noticed that breaking(stopping) power is kind of soft compare to my previous 2003 GS300 RWD
So, I checked the rotors and break pads and everything looks pretty normal. The rotor is 30mm (min on a rotor says 27mm) pads (didn't measure but looks very beefy)
What I notice that every time when I need to break it is a little harder than usual, the break pedal goes kind of long, almost to the floor, not like short on my previous with PowerStop slotted rotors and ceramic brembo pads. So car stops very lazy, I may say it is ok when I am going from 45 to full stop, but when on a highway it is kind of scary, because stoping distance is far more then my previous one. What I also noticed, when I pump break pedal it is not getting firm, like on old one after 2-3 pumps it was stiff and almost not moving, but on a new one I can pump it and it is still behaves/fils same way.
I checked leakage, no leakage, breaking fluid level normal, color is normal. I can try to bleed fluid to check if it has an air in a system.
I understand that car is heavier, but is it normal? Please advise.
Hard to know exactly what yours is like but I have had no concerns with the braking ability of my '15 AWD GS. My brake pedal does not go anywhere near the floor.
OK, I was a little dramatizing. It is not going completely to the floor. I just compare it with my old one. Where I can fill the weight of the break pedal, and the stopping power was much more efficient. I do remember that my wife sometimes complains that I am stopping to hard and she had a motion thickness kind of effect (which I apologies every time ), but now it is way refined and soft.
I wonder is everyone experience kind of same filling. I just want to get rid go that bug in my head that something is not normal. Because my first intent was to replace rotors and pads to new one like R1 Concept carbon geomet rotors and ceramic pads. But after evaluation of rotor and pads condition I will wait for a while.
So question is is it still possible issue with breaks or everyone has same fillings.
microsup (10-16-17)
Definitely not my experience - I love the brakes on my car. I would absolutely look into doing a brake bleed and flush.
If you want a more aggressive pedal feel, though, consider changing to a higher-friction brake pad. Your rotor shouldn't make a difference on that front.
microsup (10-17-17)
A little work around brakes made it a little better. Street speed - almost no issues at all. Highway speed still kind of slow stopping. Maybe it is an issue of braking pads that they are not biting enough.
I do remember from my old one if I press brakes hard on a highway, everything and everyone fly forward. On a new one the car is slows down but not quick. Will monitor it, and later on will replace a brake pads for a new ones.
nerv81
RX - 3rd Gen (2010-2015)
04-18-18 06:08 AM
Jvgs300
Suspension and Brakes
05-12-14 07:20 AM
apdimitri
09-08-13 06:07 PM
