Normal Vs Sports Vs Eco Mode
Old 07-14-17, 10:42 AM
nmlexus4gs
nmlexus4gs's Avatar
Default Normal Vs Sports Vs Eco Mode
This is my first post so please forgive me if this is not a right place to post.
I just purchased 2014 Lexus GS. It comes with Normal/Eco/Sports mode drives. I am not sure meaning of these modes ? In sports mode i feel that steering is stiffer but other than that i don't feel any other changes. Frankly speaking i don't even know what to expect.
Your comments are welcome.
Thanks.
Old 07-14-17, 10:50 AM
peasodos
peasodos's Avatar
Received 2,226 Likes on 1,450 Posts
The throttle response changes in all 3 modes.
Sport being the most aggressive and steering tightens up.
My 450h has AVS so in addition to Sport I have Sport+, were the shocks stiffen up.
I almost never use Sport+, eco for daily driving, and sport sometimes for fun. Hit 37.5 mpg on my last trip from VA to NY.
The following 3 users liked this post by peasodos:
Im2bz2p345 (07-14-17), nmlexus4gs (07-14-17), tejanp (07-14-17)
Old 07-14-17, 11:12 AM
PsykotiK
PsykotiK's Avatar
its all a lie.. its the same
Old 07-14-17, 11:24 AM
praetor
praetor's Avatar
Huge difference between Eco and Sport/Sport+ mode. In S/S+ mode, the car shifts later, stays in a lower gear longer, throttle response is improve, steering is tighter. The only difference between Sport and Sport + mode is in S+ mode the suspension stiffens up a bit for better handling.
The following 2 users liked this post by praetor:
Jordyboy (07-03-19), nmlexus4gs (07-14-17)
Old 07-14-17, 11:46 AM
jonathancl
jonathancl's Avatar
Eco looks to minimize engine rpm, lower throttle response, and maximize efficiency. It drives like a totally different car in this mode.
Sport changes throttle response and shifting. Sport also downshifts aggressively when you brake aggressively. This is one of my favorite features of this car hands down. It does a great job of assistance with emergency braking and then holds the lower gear/higher rpm for longer than Normal expecting that you will hit the gas again and go back to your previous speed. The car is tons of fun to drive in Sport, more so than my 3rd gen GS in its Sport mode.
Normal is somewhere between, probably driven by user feedback.
Personally, I love the transmission in this car: the modes really do affect the demeanor of the car.
The following 5 users liked this post by jonathancl:
ChazZ (07-14-17), drgrant (07-04-19), Jordyboy (07-03-19), medwardsr (07-07-19), nmlexus4gs (07-14-17)
Old 07-14-17, 12:01 PM
yardie876
yardie876's Avatar
Eco: throttle is toned down to lessen throttle input, HVAC level lowered
Sport: throttle is sharpened, gears are held longer, downshifts are more aggressive
Sport S+: same as sport, also suspension is tightened up, steering ratio increased
In non F Sport/Luxury GSs sport mode changes the steering ratio in addition to what's listed above, as those models don't have Sport S+ or an adaptive suspension.
Old 07-14-17, 01:05 PM
nmlexus4gs
nmlexus4gs's Avatar
sorry but what is meaning of steering ratio ?
Old 07-14-17, 01:42 PM
mcomer
mcomer's Avatar
Default VGRS 2014 Lexus GS350
Steering Ratio is how many degrees of front wheel angle changes for each degree of steering wheel angle.
Steering Ratio was a fixed number until they came up with Variable Gear Ratio Steering. When driving straight
at higher speeds you would typically want the road wheels to change angle only slightly when you steer.
When parking you would benefit greatly if the wheels would change angle dramatically without needing to
crank the steering wheel as in an ocean going ships wheel! A gearbox on the steering shaft makes this possible.
Original Poster and all, If you develop a taste for Sport (and Sport + on F-Sport/Luxury) you need to engage it every
time you intend to use it, it does not stay on after a restart. What I call Active ECO is when you act to turn the Mode
**** CCW. This will stay on until you trade in the car if you do not press straight down to get Normal or CW for Sport.
Active ECO makes the car Act quite different, A/C output is diminished, speed control response to hills and wind is ramped
back and what you might have thought, throttle is rather subdued.
File Type: docx
The following 2 users liked this post by mcomer:
nmlexus4gs (07-14-17), signdetres (03-01-20)
Old 07-14-17, 01:46 PM
yardie876
yardie876's Avatar
It tightens the ratio, meaning it takes less turning of the steering wheel that translates to movement of the front wheels. I don't know the specifics, but as an example, in normal mode, a 6° turn of the steering wheel would translate into a 6° turn of the front wheels. In sport+, a 6° steering wheel turn would translate into a 10° turn of the front wheels.
Old 07-14-17, 02:25 PM
atrac7
atrac7's Avatar
Actually, the Luxury GS models DO have AVS and comes with a Sport+ mode. It is just not as aggressive as that from the F-Sport, but the features are the same.
I own a '13 GS350 with Lux Pkg for reference.
Old 07-14-17, 02:34 PM
yardie876
yardie876's Avatar
Yea I know luxury GSs have sport+ also. My intent was to show that premium model GSs still have the VGRS. Guess I wasn't clear enough lol.
Old 07-14-17, 04:19 PM
LatinLS430
LatinLS430's Avatar
Does anybody know how the suspension is different on a Lux Pkg compared to a F Sport? I looked up shocks and springs for F Sport and Lux Pkg and as far I can tell they are the same part numbers.
Shocks= 48530-80756 and springs= 48231-30C80.
https://www.mylparts.com/auto-parts/...ber=4853080714
Old 07-14-17, 05:03 PM
peteharvey
peteharvey's Avatar
The Eco Mode and the Normal Mode is the default whenever you start the engine.
The Eco has lower gearbox shift-up points, and is reluctant to down shift, to conserve fuel at the expense of acceleration.
The Normal Mode is the norm.
The Sport Mode the gear box shifts up at higher RPM's, and downshifts more readily to maximize acceleration.
Not sure if you have the Luxury Package or the F Sport model which also have the Sport+ Mode, which also makes the steering wheel heavier, reduces the size of the shock absorber valving on rebound for more damping control and less floatiness at a cost to comfort.
The F Sport model also has active rear wheel steering, while the F Sport's shock absorbers are actually said to be firmer than the Luxury Package's on Sport+ Mode.
Normal Mode for all.
Luxury Model's Sport+ Mode:
F Sport Model's Sport+ Mode:
https://www.mylparts.com/auto-parts/2013/lexus/gs350/f-sport-trim/3-5l-v6-gas-engine/rear-suspension-cat/rear-suspension-scat/?part_number=4853080714
Yes, the Luxury and F Sport's spring and shocks are the same, however the electronic mapping software that controls the valve openings for the shock absorbers seems to be [maybe] different.
Old 07-14-17, 05:13 PM
peteharvey
peteharvey's Avatar
Can you check the part numbers for the "front" coils and shocks, because normally when engineers upgrade the car, they often take the lazy way out, and only upgrade the front coils and shocks, while the rear coils and shocks together with the front & rear roll bars often remain the same.
Old 07-14-17, 05:42 PM
bclexus
bclexus's Avatar
Received 1,991 Likes on 1,415 Posts
Steering ratio changes? Or, does the steering have a heavier feel without changing the ratio?
Quick Reply: Normal Vs Sports Vs Eco Mode
