Stuck radio volume knob = $10,000 repair?
#31
Is there a way to forestall this from ever happening? EG is it the **** itself and the tabs within it? If so, is it easy to pull it off and just put something in the bottom of the **** so that even if the tabs broke, that wouldn't sink down too far? I've seen so much of these that I try to avoid turning the radio on and off at all I just turn the volume down, lmao.
-Mike
-Mike
#32
Another similar user here. I control volume from the wheel and if I want quiet time I just mute from the steering wheel by holding down the 'mode' button.
#37
I push my radio button occasionally without a second thought.
It's very unlikely to fail, and if it does, it'll be a fun project.
#38
I ran into this problem today and wound up on this forum looking for solutions. I was able to pull the **** back out using 2 popsicle sticks and a pair of channel locks. You may need to shave the popsicle sticks down with a razor blade but should be able to get one in the top and bottom. I was careful not to squeeze too hard so as not to damage the metal and the **** came right out. I hope this method works for others. (note that channel lock images below were taken after the **** was pulled out)
The following 2 users liked this post by jlmbnd:
jonathancl (07-18-18),
peteharvey (08-10-22)
BrettKA7 (04-25-19)
Riick (09-12-22)
#41
You are replying to a rather old thread, but maybe this will help others if their volume **** gets stuck...
The best method is to use Gorilla glue or have a PDR guy apply some of his special adhesive used to pull out dents on the **** and pull it back out.
#42
spineman (08-09-22)
