Replace car battery = have to go to dealer?
Old 04-12-17, 09:37 PM
GudSht350
GudSht350's Avatar
Default Replace car battery = have to go to dealer?
Can you replace the car battery of a 2014 GS350 by yourself? Or will it mess everything up?
I ask because a friend has a Mercedes that will get SCREWED if you try to replace the battery on your own. Basically the car has to re-learn almost everything once again. So a dealership has to do it.
I understand you may lose memory presets (which I hear can be avoided using jumper cables connecting old and new battery before removal).
I'm not worried about presets reseting. I'm worried about the car going haywire and losing basic functions.
Old 04-12-17, 11:10 PM
onexcite
onexcite's Avatar
No need go to dealer for battery replacement. Just swap out the battery then you good to go.
If you worry about losing radio station, memory presets then you could use a jump cable to connect the new battery to battery terminal cable while remove the old battery.
Old 04-13-17, 01:02 AM
Boomin
Boomin's Avatar
you fine, go right ahead. my wifes IS battery died 3 times in 3 years.
long long time ago I had a Chrysler new Yorker, got it used well my battery died so now that the car was dead it resets all I mean everything. the car had a guy that would speak to you when the door was open!!! hhahaha still remember all the things it was saying.
get a good battery, XS power battery or a Stinger
Old 04-13-17, 02:28 AM
SNiiP3R
SNiiP3R's Avatar
What do you do with the old battery, just throw it in the trash?
Old 04-13-17, 05:00 AM
jtrue28
jtrue28's Avatar
Old 04-13-17, 08:48 AM
Davenlei
Davenlei's Avatar
No. Recycle at a recycling center. It has hazardous materials in it. In some states you can be fined if you dump it.
Old 04-13-17, 09:00 AM
Metsfan
Metsfan's Avatar
Garages are supposed to accept them without question or charge (no pun intended)—at least in New York. I would think that's pretty universal. Those things are toxic.
Old 04-13-17, 09:04 AM
er34
er34's Avatar
You usually get a core charge back when you return the old battery to the place where you bought the new one.
Old 04-13-17, 09:32 AM
ItzFilyO
ItzFilyO's Avatar
Received 1,046 Likes on 661 Posts
Stock battery has something like a case on it and there's some cables attached to the side of it. Do we need that case for the new non-OEM battery?
Old 04-14-17, 03:00 AM
RA051823
RA051823's Avatar
I heard BMW's were this way but didn't know Mercedes were as well. Manufactures who do this crap to their customers deserve to lose them. There is nothing special that is required when changing out a battery. It's a simple 12v system but BMW and apparently Mercedes have decided to complicate an otherwise simple system. I'm so over my love affair with German cars its not even funny. Our BMW ownership experience was a total disaster (reliability).
As for your GS350, changing the battery is very simple. I was able to swap out the old battery from my wife's GS350 and install a new one from Walmart. I like Walmart batteries and have good luck with them in the past. Definitely make sure you turn in your old battery as a "core" as it's worth at least $10 bucks.
GSLexTexas (04-14-17)
Old 04-14-17, 08:34 AM
jtrue28
jtrue28's Avatar
Pretty sure his post was sarcastic.
Old 04-14-17, 10:11 AM
RA051823
RA051823's Avatar
BMW's do require a dealer computer when replacing the battery. They claim the charging algorithm needs to be reset. Call any BMW dealer and you will have a heart attack on the cost of a new replacement battery.
samsonn25 (02-27-24)
Old 04-14-17, 10:40 AM
bclexus
bclexus's Avatar
Received 1,996 Likes on 1,418 Posts
BMW wanted $60 just to load-test a battery. NTB (National Tire & Battery) will load-test your battery at no-charge, and they now carry batteries with the special venting port for most BMWs at a fraction of the cost compared to BMW replacing the battery.
The following 2 users liked this post by bclexus:
GSLexTexas (04-14-17), samsonn25 (02-27-24)
Old 04-14-17, 10:43 AM
RA051823
RA051823's Avatar
That's cool! Do they have a computer that can also reset the charging algorithm in the car? Just curious! The only BMW I will ever own will be a E39 M5. I will never own another newer BMW ever again.
Old 04-14-17, 11:05 AM
bclexus
bclexus's Avatar
They'll always back-feed (parallel-feed) the car's system while changing the battery so nothing needs to be reset.
Quick Reply: Replace car battery = have to go to dealer?
