'14 GS 350 Oil Change Mistake
Old 01-10-17, 06:30 AM
er34
er34's Avatar
Originally Posted by punkguins
Oil filter question. I went to Amazon and purchased 5 Toyota 04152-YZZA1 filters after my last change and noticed these look smaller than what I just put in. I went thru old Club Lexus oil filter exchanges and am not sure if I should exchange or not. Seems like for my model ('14 GS 350 RWD), I should have purchased YZZA3. Can someone confirm what I need? The YZZA1 seem shorter...
Get the proper size.. putting in a shorter filter will mean most of the oil will pass through without filtering(lowest path of resistance).
Old 01-10-17, 12:30 PM
lamikela1
lamikela1's Avatar
Yeah, I have been reading threads how then pinch welds get all messed up after repeated use. I did examine the pinch welds below my Lexuss and you can see the metal surrounding it is darker, showing it is re-inforced between the two notches. This implies Lexus did expect jacks to go on those reinforced portions, not the actual pinch weld.
I'm thinking this weekend of creating my own jack cover out of wood from 1x1s but running a groove across the top of it so it won't put pressure on the pinch weld. I'll let you know how it turns out. The jack cover would then act like the grooved hockey puck for regular jacks but will be customized for my jack stands.
That is exactly what I did with some 4x6 wood blocks. I also purchased a couple of drive on ramps. I think they are called race ramps and are perfect for the GS. Now I just drive up on the ramp and if I need to remove the wheels I can get my jack perfectly placed. I then use the pinch weld adapters to support the car with jack stands. It works perfectly.
Old 01-11-17, 06:33 AM
boosteddsm
boosteddsm's Avatar
04152-YZZA5 or 04152-YZZA3 is the correct filter, YZZA1 is def too short
isosunrise
10-28-17 04:08 PM
pizdets17
10-03-10 05:37 PM
giantdefy
02-07-10 10:59 PM
dysLEXic
Maintenance
03-03-08 04:05 PM
edbro
RX - 1st Gen (1999-2003)
06-03-07 04:13 PM
Quick Reply: '14 GS 350 Oil Change Mistake
