Ebay lips fit non f-sport bumper?
#95
You may need to bend and adjust the edges to fit. Initially, I had the same issue but after bolting it on with the two main center bolts on the underside. Once its locked in the center, try to get the edges lined up and bend it. Take your time with it and be patient as it will adjust it as needed...
#99
Was a nice mod while it lasted. Hit a chunk of snow on the road and not only did the lip pop out on the side, it put a 2 inch crack in my bumper.
The snow got caught on the part of the lip under the fog light, the part that doesn't fit very well.
Thankfully the crack is not very noticeable since it's the bottom edge. I plan on plastic welding it on the back side when I take the bumper off later this spring for my bi-led headlight install.
Taking the lip off and throwing it in the garbage.
#100
#101
#102
The lip was screwed into the bumper, because it was secured very well, when the screw ripped out it cracked the bumper in that spot.
#103
I purchased an aimgain front lip for my 2015 fsport but it doesn't seem to align so I'm guessing it's for a non fsport numper. If anyone can help me and tell me if this is how it's supposed to look otherwise I will sell it.
#104
that definitely looks like for the non f sport pM me how much you want for it thanks.
