LED Turn Signal DIY
#62
Quick question. I already installed a pair of led fog lights with resistors. If I install this led turn signal with the resistor, is it safe? I don't wanna cause any burning or damage to the car
#66
Yes, the rear bulbs were a snap. I just finished the front two, holy smokes was that a pain. The passenger side is the easiest and it's still fairly tough. I ended up removing the air box just to be able to get my hand in the right position. I'm glad it's done, but my hands are still cramping.
#67
When you installed the front turn signals, you mentioned that the rubber grommet doesn't seat correctly like the original connector. Do you just have to shove it in until its comfortably sealed?
Also, do you have pics of the front end with the turn signals off? I want to see how the LED bulbs look through the housing compared to the original orange bulb.
#68
#69
Did the LED color come out as pure red with the red overlays? I just installed red overlays on my amber rear turn signals too, and wanted to upgrade the bulbs to LED, so I was wondering if amber LED bulbs will come out as bright red with the overlays as opposed to a washed out red.
#70
#71
Changed the front turn signals to LED on my 2017. Much easier to change them compared to MY2013-2015. They are much brighter than stock, and now they match the rear turn signal and mirror indicators. Highly suggest this simple mod to MY2016+ owners. Would take less than 10 minutes.
#72
#73
I have this same exact LED bulb however it is red and its for the rear turn signals if anyone interested please message me.
(Brilliant red) led turn signal for rear turn signal IJDMTOY - $20
http://store.ijdmtoy.com/Error-Free-...s-p/20-009.htm
**NOTE**
You will need a red vinyl cut out to put on the orange portion of the tail light or else you will not see red light.
This what I have installed http://www.ebay.com/itm/2013-15-LEXU...-/231382254741
**NOTE**
#75
