Tire wear and alignment
My 13 GS has been having poor tire wear on the inner front tires. Alignment is within spec. Camber is at -.5 deg. Anybody else have this problem? Anybody deviate from specs on the camber?
What's your toe at? Toe can wear tires a lot faster than camber, also short tread life is common on these.
I looked at my tires when I changed my brakes yesterday and they still look brand new at 13K miles! I have the Bridgestone and never rotated them due to RWD so my alignment must be good.
On the SC430 forum we've talked a lot about the negative camber and inner tread wear. We generally like to dial out the negative camber if we can.
Frequent rotation using the proper pattern (front to back, back cross to front) helps, but if you have the F-sport with staggered wheel/tire sizes, you can't
johnny.h
11-11-09 04:36 AM
PERRYinLA
Suspension and Brakes
03-01-03 01:38 AM
