Life of front brake rotors F-Sport
#137
#138
Only a few sets left that's available! Won't be available for another 2-3 months once rotors are out of stock.
__________________
Kevin- Sales Representative
R1 Concepts Inc.- Performance Brake Parts
Kevin@r1concepts.com
888-712-6623 Ext. 7022
#139
I'm in the same boat needing rotors and reaching out to some major brake manufacturers and parts suppliers with no luck on aftermarket........yet. They are in the works.
L-SB-0100-16(see attachment below) is the latest Service Bulletin on these and appears they have new part numbers and added shims.They went back to 1 piece rotors.and added a shim between the hub and the knuckle....they are cheaper but more work as the wheel hub has to be removed, at least the first time changing over.
43512-WY010 and 43516-WY020 looks like the new part numbers. Confirm numbers and availabilty with your Lexus dealer of course.
There is another thread on this somewhere on the forum also.....
I'm toying with the idea of placing an order for a set of oem two piece rotors and taking off those wheel hubs to remove the shims to go back to a completely original two piece setup.
Thoughts?
#141
I installed the OEM pads from Toyota/Lexus. Brake dust doesn't bother me on the graphite wheels.
Update: very squeaky when "cold" e.g. backing out of garage. But squeaks are gone by the first stop sign down the block. Don't know if there's a way to address it. Tips welcome!
#142
R1Concepts (02-26-18)
#143
my squeal like crazy, dealer said it's the rotors, but I've read that it's the pads?
#145
it's the pad that squeal. you just have to lube all the contact point except where the pad touches the rotor...that solved my squeaks. 2 piece oem + oem pads. front rotors changed at 90k...rear is still intact. changed front pads 3 times, none in the rear. changed front rotors once, none for rears. - just extra info
#146
#148
I just replaced my oe F-Sport pads with Auto Zone Ceramic pads & oe design hardware at 32K miles. $85 + tax, lifetime guaranty free replacement of parts. Very quiet but initial bite is lighter than OE & never grabs like OE pads. OE rotors have about 1/8" lip wear. I'm anticipating 30K miles with these pads & half as much wear on the rotors.
#150
zeckhausen.com just listed stoptech sport drilled and slotted rotors. I just order a set for $92 each. They also have some blank c-tek models ($57 each).
https://www.zeckhausen.com/catalog/i...4173_5661_5663
remember, f sport rotors are 356x30
