Best Wheels EVER!!!!!
I'm a conservative guy. I bought a Lexus for the first time in part because I consider the brand conservative. I'm not a modder. I've never done it, but I would make an exception if someone can tell me where I can BUY THESE WHEELS!!! Forget Vossen and every other brand. These are the wickedest wheels EVER!!!
Loves Snickerdoodles!
I know so little about wheels and tires. Bolt pattern? I've never even considered something like bolt pattern. I suppose that's why I've never modded a car. I'm completely ignorant about things like bolt patterns and this and that. I don't even understand window tint.
So if you see 5 x 108 it means 5 holes drilled on a 108mm circle. Your car needs 5 holes on a 114 mm circle, so she's a no fit.
If you'd like to see what they'd look like on a GS, click on the link below
https://www.clublexus.com/forums/gs-...ml#post8217958
Where there's a will there's a way. If you really want the wheels, you have some options, you can have the wheels re-drilled to the 5 x 114 bolt pattern or you can go the adapter route.
Those wheels definitely wouldn't be my first choice but with that being said, they don't look half bad.
