DIY, TRD ignition push button switch on 13 GS
Old 10-02-13, 11:01 PM
Khenson
Khenson's Avatar
Originally Posted by Joeb427
Yep.
Cheapens the interior.
+1 more, not a fan
Old 10-02-13, 11:37 PM
sam430
sam430's Avatar
reminds me of the "Staples- that was easy!"
it's not bad.
Old 10-03-13, 04:32 PM
Dustin2011
Dustin2011's Avatar
If you have an F-Sport, that might look pretty good. Not a hard upgrade, but I think it is more sporty then stock. :-)
Old 10-03-13, 10:57 PM
GtiB
GtiB's Avatar
not bad at all.. If you like it then stick with it ! remember, its all about you
Old 10-04-13, 02:05 AM
natnut
natnut's Avatar
I would do this only if it came with F-Sport logo rather than TRD and if it glowed blue in the dark (Blue is the default F-Sport color).
NickMayer (05-22-19)
Old 10-04-13, 07:54 AM
mrpartsman
mrpartsman's Avatar
yes sir, everybody got there taste or like to get what they want, but since this is the only thing available, and its OEM, I like it. I appreciate everybody's opinion , and don't worry I don't take it personally if u guys do't like it.
Old 08-22-15, 08:12 AM
sonyfan
sonyfan's Avatar
Question
Originally Posted by mrpartsman
this is very simple DIY install, it should not take more than 5 min. to do, thanks to Joe-Z for doing this,no tools needed at all, everything just pops right out and pops back in.as u can see in the pic, locate the edge of the trim of the radio and u can pop it out with two fingers,and pull it out gently with two hands , do not force it or u might brake it, then u can see the the yellow clip, just pull it toward u gently, u don't have to remove the whole thing out of its place,then u see the ignition switch , locate the 2 clips around the switch and press them and push it out, it might be tight and u have to put a ltl force on pushing it,unplug the wire harness behind it. Now here is the trick, u must replace the chrome bezel ring around the ignition switch, the new one is smaller in diameter so if u try to use it, u will see a gap around ur ignition switch which will look very ugly , so u just pop it nice and gently so u wont brake it from the old one and the new one u switch it, it fits one way , and the trick is locate the two tabs close to each other at 4 o'clock as u see in the pic and push it back in, then plug the harness back in,and before u put the switch back in the hole, put the trim back in, just by pressing it nice and firmly into its place, and then just test the switch , start up the car , it should start with no problem, then turn the ignition off and pop the switch back in its place, and u are done.Again thanks to Joe-Z for doing this and u can get the switch from Nigel-Jdm.
How much is the button?
Old 08-22-15, 10:08 AM
Rudiculous
Rudiculous's Avatar
~$135
I wonder if this would fit: http://www.nigel-jdmparts.com/toyota...?keyword=start button
Old 08-22-15, 04:43 PM
sonyfan
sonyfan's Avatar
Originally Posted by Rudiculous
~$135
Wanna try and let us know? 😁
Old 08-23-15, 04:46 AM
ongdia009
ongdia009's Avatar
ah where to buy it bro ? how much is it for the button ?
Old 08-23-15, 09:21 AM
sonyfan
sonyfan's Avatar
$135 check the link above
Old 08-23-15, 01:43 PM
jkeller
jkeller's Avatar
Not a fan of this one, but always appreciate it when someone takes the time to do a write up.
Old 08-23-15, 09:38 PM
BUZY3215
BUZY3215's Avatar
I got it installed in mine, looks good with the red interior.
12-07-18 05:29 PM
jp1guy
GX - 1st Gen (2004-2009)
05-14-17 02:02 PM
tradosauru
12-23-15 06:19 AM
BenzKilla
SC- 1st Gen (1992-2000)
08-28-12 11:05 AM
Quick Reply: DIY, TRD ignition push button switch on 13 GS
