4GS Fuel discussion Premium or Regular Gas? (merged threads)
Old 02-03-14, 10:41 AM
  #166
rominl
exclusive matchup
rominl's Avatar
Originally Posted by scham21
You can do 0$ down and 600$ a month leaseing a GS?? For how long??
no i wasn't specifically talking about the gs. Infamous3 talked about 50k car, 2k down/500 a month, so i am avging it out to no down monthly payment.
i don't know the ongoing lease deals on the gs but i would expect it to be between 600-700 max?
Old 02-03-14, 02:26 PM
  #167
sgmstr
sgmstr's Avatar
hmm...
this makes me wonder what Lexus puts in for you either when you get into a new car or get your service/warranty work done at the dealership.
Each dealership should at least have two gas tanks - regular and premium for different models.
Old 02-03-14, 03:23 PM
  #168
Received 2,499 Likes on 1,802 Posts
Most dealers here actually no longer have their own tanks. The cost, insurance, environmental, etc was so high they just have agreements to fuel their cars at a gas station nearby.
I remember when I was a kid the dealers having their own pumps in the back, but those same dealers nowadays the pumps are gone.
Old 02-03-14, 05:53 PM
  #169
rominl
exclusive matchup
rominl's Avatar
Originally Posted by sgmstr
hmm...
i thought all lexus vehicles recommend the use of premium?
Old 02-03-14, 06:09 PM
  #170
The ES, RX & CT specify regular nowadays.
Old 02-04-14, 12:09 AM
  #171
rominl
exclusive matchup
rominl's Avatar
really? wow, time has changed
Old 02-04-14, 10:46 AM
  #172
Yup. They reduced HP figures on the ES and RX in 2011 and started specifying regular fuel.
Old 06-08-14, 05:09 PM
  #173
GM11
GM11's Avatar
Default Which octane premium fuel?
I always use 91. Owners manual says 91 "or more". What happens when one puts in "more" than 91 then I wonder? So I pump in a tank of 93 and..... WOW!!!!
Underwhelming. There is no apparent difference in power or fuel economy, only real difference seems to be I'm 10 cents a litre poorer.
Anyone else done a proper test or persevered with higher than 91 with any success? I'm assuming there's little point but there's still this niggle: why the manual says "or more" ?
Old 06-08-14, 05:20 PM
  #174
Schmexus
Schmexus's Avatar
You're not going to "feel" any difference. Your timing *might* be slightly different, but you're most likely not going to notice any difference when accelerating.
Old 06-08-14, 06:45 PM
  #175
CincyBrad
CincyBrad's Avatar
Different regions have different octane grades of fuel available. Example, here regular is 87, mid-grade is 89 and premium is 93. " Or more" is a catch all to account for these geographical differences, mostly.
Old 06-08-14, 09:03 PM
  #176
mrpartsman
mrpartsman's Avatar
in CA we used to have 93 octane also until they changed it to 91, but anything is 91 or more is better, as long as u dont do 89 thats where ur knoking of the engine will start.
Old 06-09-14, 05:52 AM
  #177
FishBike
FishBike's Avatar
The manual says "or more" because somebody at Lexus determined they would get X number of additional phone calls asking if 93 is OK too.
But seriously: octane rating is just a measure of detonation resistance. 91 is what this engine needs to run normal ignition timing without detonation. Higher octane ratings don't improve the situation because you can't have any less detonation than the "none" you get with 91. Lower rating however will require retarding the timing to avoid detonation, so 87 or 89 will cost you some power and efficiency.
Old 06-09-14, 09:03 AM
  #178
Kayman
Kayman's Avatar
91 all the way. Had same issue with my BMW 5 series whenever I loaded up on cheap fuel my engine performance went to crap. Have to keep timing on or you will notice it.
Old 06-15-14, 10:27 AM
  #179
sambb
sambb's Avatar
Default is premium gas really necessary?
I know the manual says to use premium, but numerous sources say it isn't necessary in most cars, if not all. They say there might be a slight performance decrease, but I don't track the car.
Is there any objective evidence of necessity in using regular or mid grade gas instead of premium?
Thanks so much for your commentary.
And let me clarify, i did do a search and there seem to be strong opinions, but I am wondering if there is objective evidence on which I could base a decision. In my previous BMWs I used the middle grade, and never had an issue.
Old 06-15-14, 11:02 AM
  #180
IS340
IS340's Avatar
In my experience using lower octane gas caused extended crank and poor performance in mine!! In the northwest we have poor fuel quality anyways. I switched back to Chevron premium from Costco premium, big difference no extended crank and better performance. Never used mid grade, no opinion on that. Plus with the direct injection system, did not want to compromise pump, etc.. Based on my opinion and experiencing the conditions. My two cents
Quick Reply: 4GS Fuel discussion Premium or Regular Gas? (merged threads)
