Wheel (and tire) decisions!
Old Jun 3, 2013 | 06:16 PM
  #31
sydtoosic's Avatar
sydtoosic
well let's get to work then young man... put those new shoes on so we can drool...
Old Jun 3, 2013 | 09:51 PM
  #32
natnut's Avatar
natnut
Hi Outrage, you didn't like F Sport full-face forged 10-spoke wheels? And replaced them with Work wheels?
Can I ask what made you dissatisfied with the F-Sport forged wheels?
Old Jun 4, 2013 | 05:10 AM
  #33
Outrage's Avatar
Outrage
I returned the F Sport wheels. I was dissatisfied with the quality of the painted outer spoke surface. The paint was applied inconsistently and led to an inconsistent coloration. I cleaned the wheels to see if the discoloration was caused by dirt. It was not. The inner rim surface was not fully painted; only overspray from the outer spoke surface was found on the inner rim. This looked cheap. Finally, the tire mounting surface was significantly gouged and scuffed.
The Work wheels, by comparison, have a well-painted outer spoke surface and completely painted inner and outer rim surfaces. Additionally, I believe the Work wheels are very close in weight to the F Sport forged wheels despite being produced using a casting process.
Old Jun 4, 2013 | 10:56 AM
  #34
mso4's Avatar
mso4
Which Work wheel did you get? Size and specs? I'm thinking of the Gnosis CV 201. If possible can you weigh your wheels before mounting?
Looking forward to seeing them.
Old Jun 4, 2013 | 09:26 PM
  #35
UKNOWME's Avatar
UKNOWME
Mine with Vossen CV4s and Nitto Tires
Old Jun 4, 2013 | 10:50 PM
  #36
GS350MIKE's Avatar
GS350MIKE
Default Go with 20s...
They look great, ride great, and don't need to be lowered...
Old Jun 5, 2013 | 05:45 AM
  #37
Outrage's Avatar
Outrage
Work Emotion CR Ultimate "Kiwami" in the color GT Silver. The wheels 19" x 8.5" + 35 mm offset sized. I don't believe I have an appropriate scale, but I can tell they are fairly light from lifting them. UPS listed one of the packages at 29.0 pounds total which includes a wheel, shipping box, and packaging materials.
Old Jun 5, 2013 | 09:27 PM
  #38
mso4's Avatar
mso4
Looking forward to seeing the pics.
When you had the forged f wheels, which are lighter than stock wheels. Did you notice any performance gain?
Also how did you arrive at those offsets?
Old Jun 6, 2013 | 06:23 AM
  #39
Outrage's Avatar
Outrage
I never had the F Sport wheels installed. I believe the stock wheel is 8.0" wide with an offset of + 42 mm. The F Sport wheel is 8.0" wide with an offset of + 40 mm. The "Kiwami" wheels are available in + 35 mm and + 42 mm offsets in the 8.5" width. RavSpec, where I ordered the wheels, recommended an offset of + 35 mm. This will position the outer edge of the wheels' rims 13.35 mm away from the center line. (7 mm + 0.25 in = 13.35 mm, or, ~0.526 inches). This assumes the + 42 mm offset of the OEM wheel is correct. Hopefully, this will not be a clearance issue.
Old Jun 6, 2013 | 10:30 AM
  #40
mso4's Avatar
mso4
Hopefully you verified your oem offset from the back of your wheels. I checked my F Sport oem 19x8/9 and they were +45/60. Yet I've seen them listed incorrect on a couple posts already. FYI the forged F wheels are +40 for both front and back.
Your offset calculation are on the money so hopefully they fit as calculated. I found this calculator to be very useful:
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Old Jun 6, 2013 | 11:21 AM
  #41
Outrage's Avatar
Outrage
Hopefully, if the OEM wheel's offset is + 45 mm, the additional 16.35 mm (~0.644 inch) won't be an issue. Using the recommended Vossen values, I would have moved the outer edge of the rim 25.7 mm (~1.01 inch) away from the center line (9" rim width and + 32 mm offset). Additionally, the overall diameter of my chosen tire is slightly greater, as is the sidewall at 98 mm versus 94 mm.
Old Jun 6, 2013 | 02:28 PM
  #42
onexcite's Avatar
onexcite
I got mine Forged wheels installed earlier this week. Tires are Michelin Primacy 235/40R19. So far so good. The ride is smoother and less noise. The handling feel a bit sleeker. The F-sport forged wheels are 19x8 all 4 around with +40 offset for my AWD. I like to keep the stock height so no plan for dropping. Minimum changes in overall diameter: 26.40 in vs 26.33 in for stock 18".
Try digging a set of Vossen CV4 20" with ET38 but no ETA so went with forged instead. I'm a bit conservative so those forged wheels are perfect for me.
Attached Thumbnails Wheel (and tire) decisions!-img_2307.jpg   Wheel (and tire) decisions!-img_2299.jpg   Wheel (and tire) decisions!-img_2305.jpg   Wheel (and tire) decisions!-img_2306.jpg   Wheel (and tire) decisions!-img_2302.jpg
Old Jun 6, 2013 | 02:36 PM
  #43
yardie876's Avatar
yardie876
Originally Posted by onexcite
I got mine Forged wheels installed earlier this week. Tires are Michelin Primacy 235/40R19. So far so good. The ride is smoother and less noise. The handling feel a bit sleeker. The F-sport forged wheels are 19x8 with +40 offset. I like to keep the stock height so no plan for dropping.
Idk what it is about FAP but the fsport forged wheels look great on that car! Props my man.
Old Jun 6, 2013 | 02:57 PM
  #44
onexcite's Avatar
onexcite
Thanks!
The stock height leave a big gap but I prefer the comfort ride.
Old Jun 6, 2013 | 10:21 PM
  #45
natnut's Avatar
natnut
If only the GS F-Sport came in FAP. Those F-Sport Forged wheels go really well with the FAP color.
