Where Have you Mounted Your Radar Detector!
Old 01-18-13, 07:54 PM
  #31
Nick88
Nick88's Avatar
I just use a Blendmount and a Solo S3.
Attached Thumbnails Where Have you Mounted Your Radar Detector!-img_2115.jpg   Where Have you Mounted Your Radar Detector!-img_2117.jpg
Old 01-19-13, 01:42 PM
  #32
Vizzy
Vizzy's Avatar
Just finished installing my Escort 9500 I got the smart wire kit and hardwired it into the rain sensor wires and ground it into roof console using a 10mm bolt. Ran my wires underneath the headliner and routed the wires down my A Pillar down through out the dash and my mute button and status light is mounted by my parking brake
Ill take pics for anyone who needs it.
Old 01-19-13, 06:35 PM
  #33
Vizzy
Vizzy's Avatar
Not the best pics since the sun was coming down but here is how i installed mine
Then i ran the wires underneath the headliner and behind the A pillar molding where the side air bag is continuing down behind the weather stripping and then behind the driver side kick
panel.
The wires now run under the dash there should be a platic panel with 3 screws below the driver knee airbag thats where i tucked the wires and then mounted my smart cord display
this is the finished product
when the radar goes off i can simply reach down and press the mute button. the green status light does stay on but thats normal and when im driving i dont notice the light until i look down at the parking brake
Old 01-19-13, 10:15 PM
  #34
mso4
mso4's Avatar
panel.
Nice job! Originally I was going to do this too, except I would have put the mute button inside the dash cluster console so I can easily see the flashing red light when the RD goes off.
Any tips for pulling off the overhead console to access rain sensor wires?
Old 01-24-13, 01:31 PM
  #35
DaVeyBoyTX
DaVeyBoyTX's Avatar
Originally Posted by williakz
Then get out your checkbook and hie to a stereo shop (most also sell radar detectors). Either buy a detector there or give them yours and tell them you want a Blendmount (mounted to mirror stalk) with concealed wiring. They will smile, take your money, and you will have a perfect install. OR...
Grow a set, pull the f*ng panel, use a voltmeter to find 12VDC and ground, tap it, run the power cord, install the mount, test everything, snap panel back, and smile. Your choice.
Big thanks to Williakz and Simon, finally got around to installing my Passport 9500ix and stealth cord via tapping into the rain sensor for power. It was pretty easy based on the feedback and pictures you guys provided. I was able to use my Country Joy mirror mount that I had for my G37 Convertible. Personally I like this better than the Blend Mount, it is far cleaner and less bulky. Picture below! Sorry about the background, took this in a parking lot during lunch.
Old 01-24-13, 02:09 PM
  #36
MichaelPea
MichaelPea's Avatar
Default removing the overhead console
As williakz said previously, start at the windshield and work your way back. You need to be firm but gentle because that trim panel is tougher that it looks like it is. You might notice a little bit of flex because the panel around the SOS button is a separate panel connected to the overhead console panel but it still comes off in one piece. Don't let the flexing bother you too much though as the whole thing comes off eventually.
Old 01-24-13, 02:44 PM
  #37
williakz
williakz's Avatar
Originally Posted by DaVeyBoyTX
...finally got around to installing my Passport 9500ix and stealth cord via tapping into the rain sensor for power...
Congrats! Nice, clean install. Looks just like my wife's. Now put it in single letter display mode with vehicle speed (0mph means you've lost GPS), Highway sensitivity, low or medium brightness, and SPEC threat display (so you know what gun LEO is using on you) and enjoy! One word of warning: the 9500ix is not optimized for responsiveness (too busy scanning and crunching its database), so it tends to miss scatter coming off other vehicles being hit with instant-on radar (I/O) giving you NO WARNING whatsoever that I/O is in use ahead. BE CAREFUL! To maximize response as much as you can, turn off X and Ku bands, POP, SWS, and Laser (alert only makes you spiil your coffee and LEO already has your speed).
Good luck.
Old 01-25-13, 11:07 PM
  #38
mso4
mso4's Avatar
Just hardwire mine. Thanks everyone for all your help. I've added a few more pictures in case you're still afraid to do it.
Turns out you don't need to pull as hard as I thought you would. As others have said, start at front of car and headliner, gentle pull to pop first part of panel out. Then use your finger and slowly pull both sides of panel by running your fingers between panel and roof of car. The panel will gently pop out. Also I didn't remove any harness except the rain sensor (white/pink/green). Ground wire (black) on mirror tap goes to (white) wire on sensor and (red) wire on mirror tap goes to (pink) wire on sensor.
Took me a little longer to put the pieces together, namely the rear part of the panel. Also when putting back the front end of the panel do the front passenger side first by bending and inserting one of the tabs in. Don't just put it straight up you might damage one of the tabs. Once the passenger side is inserted you can bend/ curve the driver side in.
The following 2 users liked this post by mso4:
Im2bz2p345 (03-25-21), January8 (03-25-21)
Old 03-25-13, 05:34 AM
  #39
Lexus4EVR
Lexus4EVR's Avatar
Default Mirror tapping the 2013 GS350
[QUOTE=mso4;7726444]Just hardwire mine. Thanks everyone for all your help. I've added a few more pictures in case you're still afraid to do it.
QUOTE]
Thaks for the roadmap mso4! I completed my own DIY over the weekend, using the mirrortap cable and tapping into the rain sensor, same as others have done. When all was said and done, this was MUCH easier than I anticipated, EXCEPT the following:
Using mso4's advice, worked on re-installng the overhead panel from back to front. When I got to the front (the piece of the panel closest to the windshield), I could not get the passenger side curved piece to snugly re-install no matter what I did. I literally must have had to take the overhead panel on and off (i.e. backing up and pulling the two panel mid-clips out again so I had more room to work with) about 10 times. In fact I got so frustrated, I took a break and went inside for bit, as you really do have to be careful or you wll snap off the little platic piece on the passenger side.
After the break, came back out, tried it two more times, and on the second time I have no idea what I did,I think I maybe bent it more than usual to try and fit back in place, but it installed perfectly and was done! The job should really only take 15 minutes, but I think I spent an extra 15 minutes trying to get that last part done. I still have no idea exactly what or how I did it any different than the previous 20 times.. but mission accomplished and it looks great!
Old 03-25-13, 06:39 AM
  #40
bigblack06
bigblack06's Avatar
Nice write and DIY looks real good.
Old 03-25-13, 10:34 PM
  #41
mso4
mso4's Avatar
Glad it helped! I'm still feel really good every time I get into my car and looking at my clean install lol. And nice job getting the passenger side to fit. Lucky it only took me 2 minutes but I can see how this can take 15-20 minutes.
Thanks!
Old 03-27-13, 10:49 AM
  #42
Lexus4EVR
Lexus4EVR's Avatar
Thanks!
I thought I would share some simple pics of the finished install, I didn't even think to take some during given mso4's already detailed pictures. Note: I have coming in a couple days the square 3M tape mount that some have shared work well in these forums. I figure I should as I am in Tampa, FL and the heat does get brutual.. so I don't have a lot of faith in the suction cups this high up.
Old 03-27-13, 11:55 AM
  #43
zicogold
zicogold's Avatar
They are in my eye-sockets, in Canada radar detectors are illegal. Polices services across the country actively police these devices, they have radar detector detectors. If you are planning on visiting Canada my advice is leave your device at home.
Old 03-27-13, 04:53 PM
  #44
williakz
williakz's Avatar
Advice from a beginner. There are other ways...
Old 03-27-13, 06:38 PM
  #45
bigblack06
bigblack06's Avatar
Lol thanks, I'm traveling there next month, even if I have it off does it matter.
Quick Reply: Where Have you Mounted Your Radar Detector!
