Annoying NAV issue
Old 11-05-12, 05:05 AM
Igor911
Igor911's Avatar
Default Annoying NAV issue
Hi All,
So I've got this annoying nav issue with my new GS. When driving on the highway, the screen seems to auto-split into 1/2 map, 1/2 upcomming exit POI icons.
Is there anyway to disable this...I frankly don't care which exits have POI's and which don't!
Old 11-05-12, 05:49 AM
obadea
obadea's Avatar
easy, hit the map mode button on the map screen and you will see the different views.
Posted from ClubLexus.com App for Android
Old 11-05-12, 05:53 AM
jj14
jj14's Avatar
Hit the map mode button on the screen for options
Page 45 http://drivers.lexus.com/t3Portal/do...U/pdf/02-1.pdf
Old 11-05-12, 07:26 AM
Igor911
Igor911's Avatar
I've tried that, but this view only comes on temporarily while passing exits on the freeway...
Old 11-05-12, 07:55 AM
obadea
obadea's Avatar
that view appears when you're on a highway only. when you see it do what we said above
Old 11-05-12, 08:01 AM
Igor911
Igor911's Avatar
Thanks all, will try that while I'm on the highway next time!
Old 11-05-12, 08:52 AM
jj14
jj14's Avatar
I thought the map mode button is always visible, and so, this could be enabled/disabled whenever.... hmm.. guess not. I'll check once I get back home later this week.
Old 11-05-12, 09:03 AM
LuxoRocket
LuxoRocket's Avatar
Igor,
I suspect the "Freeway Exit List" option in the "Map Mode" screen is the one that causes the freeway exit listing to show up (see screen-shot below).
So you may want to try the following: click the "Map Mode" button on the left side of the nav screen and select "Map Only". Then drive on a freeway and check if the split screen with the freeway exit list stops appearing.
Old 11-05-12, 02:10 PM
Igor911
Igor911's Avatar
thanks all! I was finally able to disable it while driving on the highway!
gloamin
NX - 1st Gen (2015-2021)
01-28-16 08:57 AM
shouran
01-31-11 09:17 AM
grouch
06-14-08 01:17 PM
CsKWarEd
07-19-07 03:20 PM
Donger
GX - 1st Gen (2004-2009)
16
03-10-05 12:41 AM
Quick Reply: Annoying NAV issue
