Apexi Smart Accel - Install and Review
I have mine setup to reset to the off position every time I turn my car off. That way if somebody else drives, its at the stock setting every time you start the car. I don't mind pressing the button every time I drive to turn it on. I have to switch my drive mode to Sport S+ anyway.
It's a software option you can choose. Let me see if I can find an online PDF manual.
Originally Posted by Danphan
Did you wire this a specific way to achieve this? Or is that it's default. That would be ideal for me
Finally pulled the trigger on ordering and installing this! It really wakes up the car and makes it so much fun to drive. Really gets rid of the lag and the transmission always seems to be in the right gear now. Definitely worth the price. Install was easy and took less than 20 mins. I didn't have to pull any panels off and mounted the button on the space next to the steering wheel column, below the Trip/Odo button (can't see the annoying reflection of the button in the window). Now I'm going to watch my already poor fuel economy go down even more. I have it set to turn on in the last setting (purple mode) when I start the car.
Just learned that you shouldn't push past the detent on the accelerator. Causes the module to need to be calibrated again.
