Small diameter dents in Aluminum Trim Driver's Side F-Sport
Anyone notice this on their F Sport? Small dent's like the size of a sheet rock nail head in the driver's door aluminum trim. Not very noticable unless you look at it from the side with the door open.
At first I thought it must be my detailer, but he assures me they don't use any tools or devices that can cause these dents. I get it hand washed by the same group every week.
I checked the seatbelt buckle but it does not appear there is any way it can cause this problem either when taking it off, or closing the door, etc.
One possibility that we discussed is that I may be unaware that I hit my watch on the door trim when putting on my seatbelt. I wear very expensive watches and am very cognisant about hitting my watch on any surface. That is, I've learned to be very careful about accidently hitting my watch and am well aware if it ever happens. That's why I find it hard to believe this could be the cause, but I can't think of any other possbility. The only other time I left my car with anyone else is when I took it to the dealer on two occasions. I'm at a total loss.
Anyone else have this problem or care to speculate as to it's cause? Any help would be greatly appreciated. Thanks,
Just kidding . But they are large watches like Panerai and Brightling, so I suppose it's possible that I may have hit the door lightly without noticing. However, if this is the case, I think it's a design defect. Clearly, this should not happen so easily. I'm saying that if I indeed did hit the door they must have been extreamly light hits for me not to notice.
Should this be reported to Lexus as a design defect?
Its from the seat belt! I noticed a few on mine as well and realized that sometimes while i'm in a rush and take off the seat belt quickly the metal part goes flying and hits the trim. So i now have to be more careful when taking off my seat belt.
I believe the replacement part is about $150.
In any case, I believe the last post from Crzyis is likely correct. It makes sense given the amount of force possible from the seatbelt retractor. I'm going to be very careful from now on, but if this is the case, I'll bet a lot of other F-Sport owners will experience the same problem.
One last point. Does anyone know if if possible to adjust the seatbelt belt mechanism to retract with less force? Any ideas for a fix? It seems wrong to have to pay $150 to replace the trim each time ...
Received 1,058 Likes
This sound pretty spot on, and makes perfect sense..!!
I own an IS-F... I never let go of the seatbelt (with my left hand) until its close to the B-pillar..
I too have seen the very small dents on "mikec78" F-Sport..
~ Joe Z
Now that I know about it, I will definately try and make it a habbit from now on. I just wish I knew about it before the damage was done. I still think I should be able to get it replaced under warranty since it was due to what I believe is normal use and certainly not abuse in any way. Do you agree?
I checked my car.. and practiced getting in and out a few times. Not sure how you guys are doing this. My seat belt buckle stays low and is never high enough to hit the aluminum trim. Sorry to hear about the dents though, I know it'd bother me on my baby..
