350f gears stick at high revs??
Old 04-23-12, 10:20 AM
LexusNN
LexusNN's Avatar
It shifts normally under that rpm so you aren't dealing with one gear the whole time revving and going down. The whole point of sport mode is to drive sporty and fast. It holds the gears higher to get the most you can out of each gear when you are really pushing it.
Old 04-23-12, 10:26 AM
LexusNN
LexusNN's Avatar
Here is what the Lexus website says about it in brief. Hopefully this will help,
Sport S+ mode goes a step further by also tightening the suspension and increasing steering response. In both modes, the transmission's shift point is automatically altered coming into and out of corners for sharper acceleration. And for an even more engaging driving experience, steering-wheel-mounted paddle shifters offer the exhilaration of manually changing gears.
Old 04-23-12, 10:31 AM
natnut
natnut's Avatar
I found this handbook that gives a technical explanation of how the transmission and paddle shifts work :
2013 Lexus GS 350 New Model Technical Introduction Handbook
The explanation is in pages numbered 10, 11, 12 of the handbook.(the handbook starts on page 7.)
Old 04-23-12, 11:46 AM
spwolf
spwolf's Avatar
Originally Posted by JOELC
Sorry guys I still dont get it! When it is in sport mode it shifts fine until I get it over 4000 RPM, then it sticks? I dont see the rational or reason for this. If anything it is a burden on the engine and could cause problems for the driver who now has to fool around to get the thing to upshift. If I wanted to use the paddles that should be my option, but if the car is in sport mode and will not up shift naturally when gauging the MPH / RPM on its own then in my books that is a flaw. Can anyone tell me the benefit of this so I may try to understand Lexus's rational?
it is keeping you in the powerband so you can drive fast... if it bothers you, dont drive in the Sport mode! Otherwise if you drive slowly even if in Sport+ mode, it understands that you like red lights and upshifts automatically for you.
Point of the story - drive in sport mode only if you want it to drive sportly, if you want to cruise, use normal mode, thats why it is there.
Old 04-23-12, 12:58 PM
rlj4246
rlj4246's Avatar
You might go to a dealer and try one of their GS. I think you will find it does the same thing. My 09 LS did the same thing in sport mode. Held the revs for aprox 2 seconds before downshifting. I agree it's normal.
Old 04-23-12, 01:11 PM
JOELC
JOELC's Avatar
I dont know guys, maybe I dont drive like the rest of you. This issue should have nothing to do with a sporty mode or not, or if I choose to use the paddles or not. If I had it my way the car would always be in Sport + mode. That is how I drive, hard and fast. I have never experienced this with my 450HP Grand Sport Corvette or my 550I V8 sport Beemer that I run the ***** out of. The issue I still have is nothing has explained to me why at a 6000 RPM after a hard acceleration do the gears stick in a lower setting without automatically upshifting to a higher gear to stop the high RPM's that are no longer needed once you take the foot of the peddle, thus causing the engine to continue to SCREAM for no reason! If I take my foot off the gas that means I dont need the RPM's up there any more. If I did then I should be able to step on it again to get them back up. I dont need the RPM's to stay there on the if chance that the car is thinking that I might be thinking about hammering it again!
It is just not good tuning as far as I'm concerned. I understand fully if I have the thing in M mode, but in sport Drive mode without having the shifter in M position this should not be happening.
Old 04-23-12, 01:18 PM
spwolf
spwolf's Avatar
obviously you dont need to run the car in Sport+ mode, if you dont understand what you need this feature for.
How can i explain it to you that you might want to brake before the corner, or even just lift the gas a bit to slow down and then hit the gas again without car being in wrong (high) gear when it decides to shift up mid corner? That you want to use engine braking to slow down and in mid corner add gas just like you would in any manual that you left in 3rd gear.
Dont use the Sport+ mode if you dont need it.
And no, slammin the pedal on the highway ramp does not require Sport+ mode. Car will go as fast if you do pedal to the metal.
Old 04-23-12, 02:06 PM
jedimaster
jedimaster's Avatar
Exactly. A good example will be driving on a long narrow winding road. I often get to drive on those roads when I go hiking in the remote area. Long, narrow and very curvy. In that scenario, I want to be in the high RPM until I hit the visible straight line when I will up shift via the paddle. Another word, the sport mode makes more sense for cornering.
Old 04-23-12, 02:41 PM
spwolf
spwolf's Avatar
yeah, sport mode is exactly there for cornering and sporty driving when you always want to have engine in right gear for you... there are so many reasons why manual is better for sporty driving, and keeping car in gear while corner carving is main one.
...sporty driving is not, once again, gunnin it on the highway entrance :-).
Old 04-23-12, 03:39 PM
LexusNN
LexusNN's Avatar
Yeah you say it isn't good tuning but it is. That's the whole point. It is good tuning and is smart
Old 04-23-12, 07:25 PM
JOELC
JOELC's Avatar
Well, I guess I have to give it some time to try out. Just waiting for the break in time to end so I can do just that. I agree that manual is the best way to drive "sporty", but again, with Manual you have the option to shift up or down when YOU want, not when the car THINKS you want to. The difference with this set up is the driver has no control on when to shift up or down in sport mode.
Also, I beg to differ that Sport mode is only for cornering and long winding roads. 80% of sport driving is speed and the ability to control the car in any situation.
Let me ask one other thing to try to understand the car a bit more: If I am in Normal mode or in Sport mode and I hammer it will the car accelerate just as fast, or is Sport mode going to to give it that extra get up and go? Is the horsepower, torque and gear changes exactly the same or is it more limited in the Normal mode?
Thanks again guys for all the comments. I am glad you guys are here to bounce things off of!
Old 04-23-12, 08:00 PM
dseag2
dseag2's Avatar
BTW, I completely understand what you are saying because I had an Infiniti M that did the throttle "blip" to keep you in the right gear when downshifting, but I've never driven a car that downshifts and stays there even when you take your foot off the gas. (My Audi S5 had dual-clutch, so I have no idea what it did but it was magic.)
I also use Sport + while on the highway to fly past other cars, but then I'm disappointed when I'm ready to slow down and the RPMs don't drop. I think that's what you're describing. Again, that's when I push the button on the console and the car goes back to Normal mode. The RPMs drop immediately and I am ready to cruise along.
I can understand all the explanations for the car staying in a higher gear for cornering. They are really helpful, and that's the way I will primarily use Sport +.
To answer your question, there is no HP difference in Sport or Sport +, but the throttle mapping is different and the downshifts are quicker, so it definitely helps you "move along". Hope that helps.
Old 04-24-12, 05:01 AM
LexusNN
LexusNN's Avatar
Yeah sport changes gears quicker
Old 04-24-12, 01:04 PM
JOELC
JOELC's Avatar
Thanks again for all your comments. I was on the highway today and hammered it in sport+ when I was finished I just simply clicked the paddle to up shift gears. I guess every car maker has their own way. I am sure I will get used to it. I am just glad it is not a flaw on my new car!
Now only if I could figure out how to shut off the silly safety features of the NAV system where it wont let you manually input a new destination while you are driving... I mean come on!! (not to say that the Voice command feature ain't the BOMB!!)
Old 04-24-12, 08:57 PM
dseag2
dseag2's Avatar
Yeah, Lexus will never allow you to do that... especially after the "gas pedal sticking" lawsuits, so you will just have to suffer through the voice control.
Quick Reply: 350f gears stick at high revs??
