4th Gen GS Aftermarket Wheel Thread
#648
The following 3 users liked this post by pdxsc400:
#657
Hope this is the correct trend.
I was looking to find the correct size for my 2017 GS 350 f sport AWD and just to make sure:
19"x8" with a tire size of 235/40R19 and the wheel bolt pattern is 5x114.3???????
I am thinking to replace them with same size Vossen VFS-2 gloss graphite but apparently they are not making them in 19X8. I am listening to you guys since some if not all have more experience then me.
I don't really want to run into a problem since for sure Lex engineers put the 19x8 as the best option for the wheels.
Any recommendation please? Thank you in advance.
#658
I'm planning on running 20 x 10 +35 in the rear and car will be lowered on Tein Street Flex coilovers. Rear quater panels will be rolled for clearance. Will I rub with a 275/30/20 tire in there or will I be better off using a 255/30/20 instead ? Please keep in mind I also have a Figs rear camber arm I can use to run a little more camber to clear if needed.
#659
Rotiform KPS 20x8.5 +35 and 20x10 +40. Running a 245-35-20 and 285-30-20 rear. At stock height now, eventually going to do swift springs or coilovers. No running except for when I reverse out of my driveway and turn. I barely catch the inside of the inner fender behind the bumper. A quick heat and mold should fix it though.
jdmjedi (06-06-18)
