Finally fixed the rattle issue
Old Jun 23, 2020 | 11:48 AM
socaligs's Avatar
socaligs
Default Finally fixed the rattle issue
I discovered that the rattle was coming from 2x 10 mm loose front speaker screws located next to the a-pillar. The constant rattle was unbearable (yes, I know first world problem). After quick search, I was able to remove the speaker grill and tighten the loose screws with 10mm wrench. I would highly recommend checking these two screws for possible rattle problem with your GS350..
Old Jun 23, 2020 | 12:35 PM
marjenmill's Avatar
marjenmill
Nice find! Thanks for letting us know.
Old Jun 23, 2020 | 02:42 PM
richard203's Avatar
richard203
you got any pic of where that located? =)
Old Jun 23, 2020 | 04:54 PM
socaligs's Avatar
socaligs
This is not my picture but the picture indicate my rattle issue. I hope this helps!
Old Jun 23, 2020 | 05:04 PM
richard203's Avatar
richard203
oh ya mines was the passenger side that makes the rattle was it easy to pop the grille?
Old Jun 23, 2020 | 05:09 PM
socaligs's Avatar
socaligs
yup. I used plastic trim remover tool. I believe you can also use flat head screw driver (just be careful not to scratch your dash).
Old Jun 23, 2020 | 05:53 PM
MX5NES350's Avatar
MX5NES350
That must be where the rattle was coming from on the front corner driver side on the one I just traded. That was driving me insane! Thanks for sharing!
Old Jun 23, 2020 | 05:56 PM
socaligs's Avatar
socaligs
Yup, the rattle was driving me nuts!!
Old Jun 23, 2020 | 06:06 PM
PauloFR's Avatar
PauloFR
I'm subscribing just in case. I believe the right speaker grille, a while ago, sometimes made plastic expanding noises when going on bumps. But it may be the speaker screws as we can be surprised and I didn't do a complete check of all possible rattling sources. I work the same way, when I had my dashboard creaking, I tried to convince myself come on, this is a car dashboard noise, there are wars and starvations going on in the world but it still drove me nuts 🤦 It's been a week since the rattles suddenly all decided to go away though, so I might as well enjoy
Old Jul 7, 2020 | 02:49 PM
4GS's Avatar
4GS
I hate rattles! I thought that Lexus was really great with keeping cabin sounds to a minimum but I am not sure I know how it is holding up over time. I may have just became more sensitive to cabin noise. Overall still a smooth ride though
Old Jul 7, 2020 | 02:54 PM
socaligs's Avatar
socaligs
the worst offender was my 06 GS300. Even after countless hours of DIY rattle prevention, nothing worked..
Old Jul 7, 2020 | 03:55 PM
PauloFR's Avatar
PauloFR
This is my car and it hurts reading this because I spent and I'm still spending countless hours trying to stuff spaces with felt, disassembling things, test driving to see if it made a difference, and searching the Internet about those noises.
I'll probably look for a 2008 or 2009 GS350 this winter, so I can drive them in cold temperatures to check for noises. And yes I'm still interested in 3rd gen GSs, because all the qualities engineered into them are there... Engine, comfort, style etc. However. If the 2nd one turns out to have the same problems some hours or days post-purchase despite how in-depth I'm going to check against them, I'm giving up on these cars. Hope there will be enough left with reasonable mileage.
Old Jul 7, 2020 | 04:24 PM
socaligs's Avatar
socaligs
I enjoyed my 3rd gen GS's. However, I do not recommend getting 06 GS300. Try to get anything above 07+.
Old Jul 7, 2020 | 08:25 PM
PauloFR's Avatar
PauloFR
Yes, this is what I learned the hard way. I still can't wait for my first 4GS. They seem so much better put together in that regard. That said, the paradox is everywhere you touch is made of some nice material already in the 3GS. This is the way it is put together which has gone wrong. At least, my car isn't subject to reliability issues that I discovered to be frequent on 3GSs as well according to forums, which surprised me a bit.
Old Sep 20, 2020 | 03:01 PM
UPWA's Avatar
UPWA
Default Where did you hear
Did you hear noise from b pillar and it was coming from speaker?
