Lexus GS acting weird
My parked car was emitting some very strange buzzing noise at the back. Starting and shutting down the car engine killed the noise and I've been noticing the vsc light flashing for 5 seconds occasionally on some trips when I braked the car in traffic. Anyone here has similar problems before?
Originally Posted by Cathy
(Post 9730283)
The VSC light flashing could be triggered by a few different things that will cause the VSC light to flash, yet the cause might not have anyting directly to do with the VSC per se. It would be best to have Lexus pull the code (if the problem has even thrown a code) to find out exactly what is causing the VSC light to flash. It could be an engine sensor, O2 sensor, ignition coil, etc., etc. If you detect that the engine's power is acting strange, or if the car's speed is being deliberately reduced at times, then the problem (whatever it is) could be causing the ECU to deactivate the VSC and flash the light. I'd have Lexus take a look... |
I want to elaborate the fact that the car was emitting buzzing sound when it's already shut down in the garage.
(Post 9730349)
The humming noise you hear coming from under the vehicle hours after turning Off the engine is the fuel evaporation leak check. Any time up to approximately 5 hours after the engine is turned Off, you may hear a humming sound coming from under the vehicle that could last up to several minutes. This is the sound of a fuel evaporation leakage check and, it does not indicate a malfunction. |
Click ► HERE
Look at the 2nd Question in the GS 350 manual (on Page 8) titled 'Noise from under vehicle after turning off the engine' |
Wow thanks alot!
(Post 9730381)
Wow thanks alot!
You're very welcome! |
that's weird i haven't seen that before. if you still got warranty bring it to a delar
Originally Posted by Ehsun
(Post 9731010)
(Post 9731010)
I wonder if the flashing VSC is due to OP triggering the hill hold feature, which is activated by pressing the brake all the way when at a stop. Does the car beep before the VSC light starts flashing? |
