Changed my front brake pads
Old Aug 24, 2016 | 02:20 PM
vinnier6's Avatar
vinnier6
Originally Posted by Davenlei
What is the part number for the cmax gold pads you used?
dg1586.......
Old Aug 25, 2016 | 10:35 PM
Wincer94's Avatar
Wincer94
ItzFilyO, I thought you changed your break pads about a year ago to Autozone Duralast Ceramic pads?
Old Aug 26, 2016 | 08:27 AM
Davenlei's Avatar
Davenlei
Originally Posted by vinnier6
dg1586.......
Thanks for the info. I looked up the part number on Autozone site and it says it does not fit my RWD 2013 F-Sport. Here are the ceramic options I was given:
DGC1686 Duralast Max $74
DG1118C Duralast Gold $49
Does anyone have experience with either of these? I see some people use the DGC1686 for the F-sport and seems to have good results (they are identified as 'better than stock' pads on the autozone site) but the DG1118C is labeled as a ceramic replacement for the stock pads which include high friction compounds to work like stock.
Old Aug 26, 2016 | 07:29 PM
ItzFilyO's Avatar
ItzFilyO
I did but I changed it back to the OEM pads cause my car can't stop on a dime. That's something to keep in mind when changing to different brake pads, u may need to get ur rotors resurfaced first.
Old Aug 27, 2016 | 07:08 AM
vinnier6's Avatar
vinnier6
the ones I listed will fit your car...you want the cmax gold...they list different part numbers because over the years of the gen 4 car Lexus changed the composition of the pad, but not the caliper itself...so they all will work. Some brake manufactures only list one pad for all 2013-2016 gs reguardless of which trim level you have.
and for the record, my car stops on a dime
Old Jun 12, 2017 | 10:19 PM
djkidd's Avatar
djkidd
Do you know what the difference is between the Duralast Gold DG1568 and the Duralast Max DGC1686? There seems to be a big price difference ($36 and 75, respectively) and both are ceramic. When I looked both up, AutoZone's website says both will fit the 2015 GS350 F-Sport.
jadoocian
RC F (2015-present)
Jun 9, 2017 10:55 AM
DorianE
RC - 1st Gen (2015-present)
Jan 8, 2017 04:18 AM
rbeermann
Nov 5, 2012 07:14 PM
B5k
Suspension and Brakes
Jan 4, 2011 06:22 PM
IS3CM
Wheels, Tires & Brakes Forum
Nov 22, 2004 04:54 PM
