TPMS sensors
Old Dec 12, 2015 | 12:39 AM
terrycs's Avatar
terrycs
Originally Posted by onexcite
Both 30060 and 30070 will work with 4GS. I got mine 30060 program as 2nd set.
Here is the link you guys could buy direct OEM sensor from them: http://www.tpms.com/category_s/5468.htm
Sorry for the thread resurrection ...
What do you mean you programmed a 2nd set? Does that mean you can swap between 2 sets of wheels/tires at any time and the car reads both correctly without the need to reprogram each time you swap?
Old Dec 12, 2015 | 08:17 AM
Stylnhonda's Avatar
Stylnhonda
If you get the correct OEM TPMS part number are they plug and play or do you still need to get the dealer to program them? On my Honda Pilot, I just purchased some OEM Pilot TPMS sensors and once I put them on the aftermarket wheels the car recognized them. Then I could just switch from the OEM setup to the aftermarkets with no issues!
Old Dec 12, 2015 | 09:10 PM
peteharvey's Avatar
peteharvey
Normally, Lexus pumps tires to 30 PSI [roughly 10% below the recommended pressure], then they press the TPMS button under the steering wheel to program/set/memorize the warning PSI pressure level.
After programming, Lexus will then pump the tires to the final pressure level of 33 PSI etc.
If the programmed warning tire pressure level is too close to the actual tire pressure itself, then the orange warning light will annoyingly go off all the time.
If the programmed warning tire pressure level is at, or higher than the actual tire pressure level, then the orange warning light will also go off all the time.
The programmed pressure level must be about 10% below the actual pressure level.
Thus the low warning pressure level is programmed first.
You can have a second set of tires, and you only have to reprogram the warning tire pressure level, if the warning tire pressure level will be dramatically different from the two sets of tires.
Just be aware that if you program the TPMS warning for 30 PSI, then the warning light won't come on till pressures drop to 30 PSI, regardless of how many different sets of wheels you use.
Old Dec 12, 2015 | 09:45 PM
SNiiP3R's Avatar
SNiiP3R
You still need to program them. GS will only take 1 set of sensors. If you buy a 2nd set for your aftermarket wheels, then dealer will have to delete your original set and register a new one. So, to make the story short, every time you switch your wheels, you need to reprogram TPMS.
Old Dec 12, 2015 | 10:42 PM
peteharvey's Avatar
peteharvey
Good info SNiiP3R...
Old Dec 14, 2015 | 02:28 PM
Stylnhonda's Avatar
Stylnhonda
That blows.
Old Dec 14, 2015 | 03:29 PM
SNiiP3R's Avatar
SNiiP3R
Well, there is a solution for that. Buy the ATEQ tool and program them yourself. Yes, the tool is a bit expensive, but think how much money you will save down the road.
Here is the link,
Amazon.com: ATEQ QuickSet TPMS Reset Tool: Automotive Amazon.com: ATEQ QuickSet TPMS Reset Tool: Automotive
Old Dec 15, 2015 | 08:18 AM
Stylnhonda's Avatar
Stylnhonda
Good idea. It is pretty pricey. Damn luxury cars!
Old Jan 6, 2016 | 11:01 PM
terrycs's Avatar
terrycs
Best price so far:
http://www.tirerack.com/accessories/...toring+Systems
ACP84
NX - 1st Gen (2015-2021)
Nov 10, 2020 09:53 AM
dmk720
May 30, 2016 09:12 AM
NYKnick101
Nov 18, 2014 12:07 PM
IS250Slvr
Mar 3, 2014 03:36 PM
Deros
CL of Hawaii
Feb 1, 2012 11:52 AM
