Transmission Solenoid Replacement (Code P0751) *Video Inside*
I’m getting a P0751 code and my car has a very very heavy jerk after the first gear change and the second. Here’s a video
https://streamable.com/ln33vl
Hard to see but it literally jerks so hard you can see me get pushed back.
Now the only code that shows is the P0751 which correlates to Shift Solenoid A. If Solenoid A correlates to Gear 1, how come I’m also getting a jerk after the second gear?
Also, should I just replace all the solenoids and replace the transmission oil?
Here’s a ebay item that has all 9 solenoidshttps://www.ebay.com/itm/9x-Transmission-Solenoid-Kit-Shift-Complete-for-Lexus-IS250-GS300-IS300-05-17/133522656559?fits=Year%3A2006%7CModel%3AGS300&hash=item1f16920d2f:g:hOYAAOSw0vVfZF1T
Would this work? Cause everywhere else I’m looking each solenoid is $100-200
Has anyone tried installing these ebay solenoids?
I’d also like to add that I bought the car used and it has 187k miles. I’m not sure if the transmission fluid has ever been drained and filled. Should I change the fluid?
I would do a drain and fill, with toyota WS fluid. Where you would drain about 3-4 qts and refill it. You replace exactly what you drained. If the issue doesnt get resolved, then your ecu maybe at fault. There are ecu repair shops that repair the 2006 GS300 ecu's for $115. You mail yours out, and they repair it for you. Inside the ECU houses the transmission module. SIA Electronics on ebay are what most use.
FrankReynoldsCPA
Jan 3, 2021 12:34 PM
