Lexus GS300 III won't start.
Hello. I have problem with my Lexus gs300 2007. After replacing alternator for brand new, I can't start a car. All the lights are good, I can listen a music, Navi works fine etc. Just engine won't start. The fuel pump sounds good , also specific starter click under the hood, so here everything looks fine. After connect computer was many fault's, probably the reason was unplugged battery. But any fault's wasn't connect with engine starter. Where is the problem? I hope you guys can know a reason
did you read your ecu yet?
Originally Posted by Kapitan
(Post 10909979)
Originally Posted by enshiu
(Post 10910200)
Originally Posted by GS460V8
(Post 10910267)
Do you mean the starter is only clicking? If that's the case it could be a dodgy starter... and on the back of that question is it still winding over and just not firing?
Sounds like a dead battery! I would grab a voltmeter and measure the voltage, it can also be worn out battery terminals is another thing to look for.
Originally Posted by ibidu1
(Post 10910727)
I am not sure if I disconnected battery when installing new alternator..... That's a golden question now :sad::uh:
Any one know where is 150a alternator fuze in this model? |
12.2 volts after a charge sounds like the battery has bad cells.
https://cimg9.ibsrv.net/gimg/www.clu...fe88adb0af.jpg
I miss to ride :sad: |
Ok, I checked already fuse, relay starter and the battery all looks fine. It's very difficult access to starter I can't hit it with hammer, that's sometimes helped. Some ideas?
So when you charged the battery and used another car to jump start it, did the starter try to spin at all? Maybe find someone who has better jumper cables so you can try to see. Its possible the starter is bad, but why would the electronics in the car shut down, I am still thinking you have low voltage, maybe see if you can swap in a battery from a different car
(Post 10911166)
So the starter never worked at all after the alternator repair? Then more likely you left something unplugged or unbolted. Maybe find a mechanic that can help you go through your car at home, or tow it to a mechanic shop.
(Post 10911307)
How did you do that?
| All times are GMT -7. The time now is 12:57 AM. |
