LED low beam conversion?
Old Aug 14, 2020 | 09:37 AM
FortuneLS's Avatar
FortuneLS
Default LED low beam conversion?
Has anyone done an LED low beam conversion? I want my low beams to match the highs and fogs, and frankly, im tired of the HID heat yellowing the inside of my lenses. Curious what an LED conversion would entail.
Old Aug 14, 2020 | 06:07 PM
PauloFR's Avatar
PauloFR
Truthfully, HID housings don't easily accept LED bulbs. Halogen reflectors yes, but not HID projectors. If your goal is to match other LED bulbs, I highly recommend you putting Osram CBIs. They are 6,000K bulbs and match LEDs very well. Moreover, they're known to light up the road further than the OEM Philips or Osram 4,300K, last a long time and be well made.
Old Aug 14, 2020 | 06:44 PM
FortuneLS's Avatar
FortuneLS
I know from past experience that LEDs don't match HID output in projector housings, however, i also know there are LED bulbs made specifically for projector housings that work VERY well. My main goal isn't so much color matching, as it is lowering Temps inside the headlight housing in order to avoid the yellowing on the inside of the lenses cause by the heat of the HID bulbs.
Old Aug 14, 2020 | 07:30 PM
In my experience LEDs generally don't work well in reflector housings (bad beam pattern) better in a projector. BUT, for whatever reason LEDs tend to be more dim in a projector which means you need a very bright LED. Only way I figured out what works in my cars is buy several LED kits, not ideal I wasted money.....
LexusGXFan
GX - 2nd Gen (2010-2023)
Dec 29, 2019 10:55 AM
jk08
Jan 17, 2018 11:15 AM
jmack2688
Mar 12, 2015 11:45 PM
Pinoyako
Aug 27, 2011 02:50 PM
