Suspension noise. What am i missing
Old Dec 8, 2019 | 06:41 PM
nismo2lex's Avatar
nismo2lex
Default Suspension noise. What am i missing
Replaced all the suspension on my 2007 GS450h. New Front factory struts and Tanabe 1inch lowering springs. Also changed the top strut tower mount. While driving over bumps, i still hear a metal clank noise from what sounds like the left front. Any ideas on what i might still need to replace? Smooth as glass on the highway, its just the annoying little bumps. Possibly my mechanic installed the springs wrong too? I am also 100 percent sure i have a wheel bearing going on the same side but my Lexus dealer keeps saying it is just tire noise(with 2 different sets of tires). My Lexus dealer also thinks i put the wrong struts on the front but my research says otherwise. They are 48520-30181 KYB.
Old Dec 8, 2019 | 11:37 PM
ibidu1's Avatar
ibidu1
Try installing a gopro or an old camera pointed at the suspension and record a video of you driving. Maybe zip tie it or duct tape it
Old Dec 9, 2019 | 07:02 AM
RXGS's Avatar
RXGS
Sway bar endlinks
Old Dec 11, 2019 | 01:48 AM
Moisture's Avatar
Moisture
most likely it's a bad control arm.
Old Dec 11, 2019 | 08:29 AM
MX73's Avatar
MX73
It could be your brake pads slightly moving in the calipers. Mine has been doing that until I add shims to stop the metal clanking noise.
Old Dec 13, 2019 | 12:41 PM
vol96's Avatar
vol96
Ditto RXGS.
MarcoP
17
Dec 22, 2019 10:22 AM
gabzor
Feb 26, 2017 05:53 PM
Ludogg44
May 29, 2014 12:50 PM
alaskaty
Feb 12, 2008 07:27 PM
malhokc
RX - 1st Gen (1999-2003)
12
Mar 28, 2003 06:46 AM
